Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: Abiella on November 10, 2011, 06:42:13 PM
If I bought the Right door handle - http://webshop.fiat500126.com/index.php/katalog/artikelinfo/2822-1-door-handlelock_right_chrome_with_cylinder_und_keys.html
and then the left - http://webshop.fiat500126.com/index.php/katalog/artikelinfo/2821-1-door-handlelock_left_chrome_with_cylinder_und_keys.html
Surely the keys would be different for both sides?
They don't seem to sell these as a pair??
Confused!
You can get them as a pair from 126fan.sk. I asked since i only needed one and they said they can sell them separately. I instead found one somewhere else and so in the end i had separate keys to the ignition, left and right hand doors, fuel cap and bonnet :)
Great thanks... I'll check 126fan.sk
I have got abit of rust on my old black ones and they are fading grey so I think some nice new Chrome ones for Christmas would be nice!
Haha... so you have a very heavy set of keys!
I bougt a set of locks from 126fan.sk
Is there somewhere any guide or does somebody have experience how to change all locks to new ones?
(http://www.126fan.sk/eshop/images/p1000701.jpg)
:$ good luck. I removed and changed door handles, cut hands, bad language, and a lot of fiddling.
It is a pain in the A%$£.
But if I managed to do it I am sure anyone can :D
Agree, much easier if you buy a complete door handle than just the barrels...
On the reverse side of the lock there's a pin that holds on the thingy with the ball joint on it (where the plastic rod is attached to.) I think getting that off is the hardest bit as it is made of some sort of aluminium cast and could be a bit fragile (and if the ball joint part breaks off you can't mend it). Also it has to fit tightly onto the end of the barrel: as it roates it has to provide enough lift through the plastic rod to
the latch so that the door can be locked and unlocked. One reason i had to change mine was because it was very worn around that part and no amount of fussing around helped lock it properly.
