Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Hazey-n-Marc on October 31, 2011, 01:02:42 PM
Hello
Had a problem with car cutting out when changing down and off throttle, ticks over and starts fine, only needs choke for a minute or so, runs fine (apart from cutting out).
Removed carb and found one of the pivots for the vacuum advance linkage (I think, cant find a picture of this side of the carb), it's the weber on a bis (30dgf?). Found the washers laying in the base plate, so don't think it was removed on purpose.
Does anyone know what this bit is called, and where to get one.
Posted in this section as a lot of people seem to have had similar symptoms, but this cause has not been mentioned.
Marc
Or even a recommended bodge would do.
Marc
