Fiat 126 Chat => Fiat 126 Chat => Topic started by: skelz on October 02, 2011, 08:27:30 AM
Title: Powder Coating
Post by: skelz on October 02, 2011, 08:27:30 AM
Hey all
I have sent my tin work for powder coating (surprised how cheap it was)
wondering if I can paint the Carbi on my little one ? Could this be powder coated ? has anybody painted their carbi ?
I have hit the exhaust outlet/elbows with Pot Belly Black, any body had success in painting the exhaust itself ?
Title: Re: Powder Coating
Post by: nrg19uk on October 02, 2011, 12:04:44 PM
I think you would need to strip the carb down as there loads of parts that can be ruined from the heat process like little rubbers etc you would need to tape up all the areas you wouldn't want to be powder coated. Lots of work but can be done I'd say.
I tried the heat proof paint but it's no good I was thinking about getting high temp powder coating but it chips easily So not sure what to use.
Post by: GTMaster on October 02, 2011, 07:32:07 PM
I painted the exhaust (mainly the muffler) and cooling fan with silver heat resistant paint but it flaked off.... the thermostat housing, valve cover, oil sump and engine cowling turned out well (i used heat resistant black paint).
Post by: dajwid on October 03, 2011, 02:19:05 PM
My tinwork was all powdercoated, Nice shiny black (now silvery due to the heat).
Post by: skelz on October 03, 2011, 02:21:10 PM
I have gone with Flamin Red,,, and got the block gently sand blasted...
Post by: nrg19uk on October 06, 2011, 11:19:55 AM
I was wondering would it be possible to use brake caliper paint I know it's expensive and designed for extreme heat variables.
Advantages would be you can use a brush to apply it and can handle serious amounts of abuse.
Not sure about being in contact with petrol thoe.
Post by: Rusty's Uncle on October 06, 2011, 06:44:21 PM
If your brake callipers got half as hot as the exhaust elbows then you would be boiling your brake fluid and getting vapour in your brake lines.  :o
I think that powder coating is great and have had loads of bits done. If you are having your engine tinware done check that there is no grit from the sand blasting hidden up inside the rocker box cover. I found out the hard way when my totaly rebuilt engine with all the goodies was ruined within 150 miles  >:(
As for the exhaust elbows I have tried the highest temp paint I could find on chemicaly cleaned elbows which were then baked in an oven and the paint still flakes off after a while.
One solution would be vitreous enamaling and I did get a quote once but it was about twice the price of new elbows. There are also other firms who specialise in high temp coatings for manifolds and exhausts but again it is cost althogh one firm I came across was planning to launch a DIY kit so you never know  :)
Post by: nrg19uk on October 06, 2011, 08:09:40 PM
I know it's no good for the elbows  :P I was thinkin more of parts like the carb, the base of the exhaust, brackets etc
Post by: KAL SPL on October 07, 2011, 02:47:21 AM
Mate does powder coating for a living and expressed concerned with oil deterorating the powder over time so I did everything in 2 pack , also anything over about 180 degeers C will start to melt and ruin the powder coating.
As I fitted a brand new carby I didnt see much point in painting it.
(http://i182.photobucket.com/albums/x127/KAL_SPL/Cars/IMG_0280.jpg)
I also got a brand new exhaust which I suspect over time may start to look average but will see how it goes.
Post by: skelz on October 07, 2011, 10:02:20 AM
I too have a new exhaust..but i agree I think it will look sh7T over time..
I am going to clean up the carbi as much as possible and then prob give it a spray of something out of a can..
KAL I have a filter fitted to the line that goes to the top of the carbi. Black in line ugly looking thing noticed you dont have one ??? I was looking at getting some shiny pipework and new in line filter for mine...
I also have a black plastic thing mounted on my side wall that looks like some sort of overflow? little pipe runs off main black air intake to carbi.. where have u hiddend yours
lastly have a electric fuel pump and ugly cheap fuel filter mounted on my wall which I am going to replace with braided lines and maybe one of the inline glass (or billet) filters..
Post by: Rusty's Uncle on October 07, 2011, 11:25:00 AM
Why don't you just clean the carb ?
Online fuel filters are not standard and I would only fit one if you think you have a problem with muck in your tank. The cheap plastic online filters are a potential danger in the engine bay on the aircooled motors as I have mentioned before. If you want a filter I would go for that glass one. Stainless braided hose works well for me. Also on a standard car you have a filter inside the tank, a filter in the fuel pump and a filter in the carb.
Post by: KAL SPL on October 07, 2011, 12:00:38 PM
The black 'filter' inline you speak of is only an induction noise suppressor.
The other black container is your pollution cannister , mine never had 1 so didnt bother trying to find 1 , its only there for emmisions.
I have a second fuel filter but its mounted between the tank and the floor where the hose comes through so hidden away but as said not really needed.
Post by: skelz on October 07, 2011, 01:33:09 PM
Thanks guys. Emission canister will be removed and so will that noise supression things as well. Might get some shiny customer pipe work to replace it. KAL i love the clean uncluttered look of your engine by
Post by: Rusty's Uncle on October 07, 2011, 03:09:20 PM
Kal , I see that you have not got the heat shield/deflector plate that fits over the exhaust box. Are you going to fit it as that will help to keep the engine bat a little cooler.
Post by: KAL SPL on October 08, 2011, 03:59:10 AM
Nar mate its never been there and dont have any issues with heating.
Skelz : it may be uncluttered but the bay itself has holes and defects everywhere that in time will b smoothed and resprayed , why all the effort I cant explain but it keeps me off the streets.
