Fiat 126 Chat => Fiat 126 Chat => Topic started by: Funkin Go-nut on September 07, 2011, 12:08:05 PM
Any tips for replacing the cooling fan on an aircooled?
Does the engine have to come out or can it be done in situ?
FGN :) :)
I did it a good few years ago so It can be done with the engine still in but it's a bit awkward. Itook the top cowling off then split the front and back to remove. Remember to remove the the air scoop for the sump, can't remember if I had to remove the fuel pump.
Ditto the puddle. I did it in situ, twice on the same day in fact, after I blew my fan.
You can leave the alternator or dynamo and the front cowling in place & no need to remove fuel pump.
I did not do it twice just for fun. I got the whole thing back together then when I drove the car out I spotted the fan woodruff key on the ground. So had to do the whole thing over again but this time making sure the key stayed in ;D
I shall have a go at this later this morning, thanks for the tips :)
Job done, fan was hitting the inside of the shroud, now fixed :)
Fairly straightforward as mentioned above but finding nuts without being able to see properly was a pain.
When putting it back to gether I started to tighten the bolts but found that the holes didn't line up so I left everything loose before final tightening to align the shroud to sit correctly.
Took about 4 hours in total with lots of tea breaks...
