Fiat 126 Chat => Fiat 126 Chat => Topic started by: Amateb8 on September 05, 2011, 01:45:20 PM
Just to confirm - I still need the above for my blue 126 Bis. I have a dumb question. In the absence of a secondhand re above, can I use the screen washer bag and electric pump of other cars? Subject to the shape of bag or plastic container, the pump should work as it also uses 12v. There will probably be issues with fuse amperage. What do guys think?
Shouldn't cause much trouble. If it's the pump motor, you may fit another one to the existing water container with some fiddling i guess.
I found his universal windscreen washer with pump.
http://www.ebay.co.uk/itm/UNIVERSAL-12v-WINDSCREEN-WASHER-BAG-KIT-/250593405071?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a5887e88f#ht_2039wt_1141
Think there was one in that bunch of stuff I took to Retro Rides
Kindly check and let me know please if you have one.
There's a chap on eBay breaking (heartbreaking) a 126 Bis for spares so he will probably have the part you need at an affordable price. I don't know how to insert the link but if you search 'fiat 126 bis' using 'all categories' you should find him, he's based in Blackpool.
A few cars in the fiat range used bags for their washer fluid. If they are all a standard size a scrap yard might be a good place to look.
