Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: Rusty's Uncle on July 21, 2011, 08:56:15 PM
Title: Oil Catch Tank
Post by: Rusty's Uncle on July 21, 2011, 08:56:15 PM
OK don't laugh but this is new territory for me. I just bought an oil catch tank kit from eBay. It all looks like a nice little item but I have no experience of these things to the extent that I just realised I was thinking of fitting it upside down  :$  It has the in & out connections , a drain plug  and what looks to be a pressure relief valve to fit on the out hose . Does that sound right ?
Title: Re: Oil Catch Tank
Post by: smallcox on July 21, 2011, 09:18:36 PM
sounds like an UDDER to me :P
Post by: Allan on July 21, 2011, 10:03:04 PM
There is a name (after a bird) that collects shiney things Rusty.
And as for you Smallcox there is a song that goes something like---
"pass the udder udder over to my udder brother and pass the udder udder this away"
Post by: Darrell on July 22, 2011, 10:38:26 AM
Pressure relief... not sure if that's so clever but play and see how you go, might only hold back a very small amount. I had visions of blowing out seals for a minute there.
I have sketched a design for a catch tank where one would employ the use of a non-return valve on the drain so as to automatically return the caught oil to the crankcase.
The concept being based on the assumption there would be some pressure within the crankcase to shut the valve when the engine runs.
I've also toyed with the idea of additional breathing from the bottom end via the now redundant fuel pump mounting where a plate now resides. When I saw Smallcox's engine, he had already done this.
Would be great to see some pics of your shiney new catch tank :)
Post by: ciaoflyer on July 22, 2011, 05:23:08 PM
Here's my home made one....
http://club126uk.co.uk/smf/index.php?topic=2599.0
still not fitted it ::)
Post by: Rusty's Uncle on July 22, 2011, 06:31:26 PM
I was thinking of something like this unless there is an udder way to fit it. Thought I would start with a lean mixture and don't want to be bullish about this or cowtow to pressure so will chew the cudd for a bit. Breathing from the bottom end , just don't go there  :o
Post by: dajwid on July 22, 2011, 09:03:40 PM
That is how I fitted mine, then fitted a small filter on the other outlet.
Post by: fiatmaluch126 on July 23, 2011, 06:56:51 AM
Sorry, what's an oil catch tank do?    ???
Post by: dajwid on July 23, 2011, 09:54:25 AM
Catch oil  ;D
Post by: Kipster on July 24, 2011, 07:34:09 AM
i'm guessing this system is employed when removing the standard air filter/breather?
Has anyone noticed any gains using a non standard filter, is it a worthwhile mod?
I did use a catch tank (2litre lemonade bottle) on a knackered VW Polo i had a few years back, it would be full every 100 miles, i would then pour the oil back in the engine and repeat the process  :D.
Post by: Rusty's Uncle on July 24, 2011, 09:57:36 AM
Re air filters, on my 499ccs engine with the reworked head I fitted the later 126 air intake as it has a better flow than the 500 one. When Mr "cylinder head tuner" saw the car he said that a straight down inlet might be better. So as an experiment on this 652ccs engine I have bought and modified a ram tube for an SU carb. No filter at all , just a mesh to keep out bricks and small creatures  :D
So as the engine breather now has nowhere to go I will need the oil catch tank. I found out what the mystery item was in the kit. I was just a hose connector or a blanking plug depending upon which bit you use.
Post by: fiatmaluch126 on July 24, 2011, 10:40:18 AM
i'm none the wiser regarding what's an oil catcher! Where is it? and what does it look like?   :(
Post by: Kipster on July 24, 2011, 08:11:14 PM
if you were to remove the standard air cleaner the hose that vents from the crank case/engine has nowhere to go. It can either vent off into the atmosphere and poison us all or the tube can be routed to an oil catcher. The catcher will collect oil residues and hopefully prevent you being overcome by crankcase fumes as you drive. In the standard set up the fumes are drawn into the air cleaner and and get burnt with the normal combustion cycle. It is not a the Green way to go :D.
Post by: thepuddlejumper on July 24, 2011, 09:03:02 PM
I just fitted an oil breather directly to the socker cover outlen on the 650 in my Gamine, had no bother not noticed any oil in the area well other than the usual leaks.
Post by: Kipster on July 24, 2011, 10:01:53 PM
No oil is good. To be honest if you are gettting oil in the catcher, or in the breather pipe, your piston rings are shot. (sump compression).
Post by: fiatmaluch126 on July 25, 2011, 08:36:16 AM
ok, i think i understand!   :-   thanks Kipster and all    :$
Post by: Darrell on July 25, 2011, 09:30:42 AM
When you have two pistons going up and down at the same time at speed you'll always get a bit of sump pressure. I guess standard there isn't much to talk about but does anyone still run a standard 126 any more?
I hope you charging that supermarket for advertising Rusty  :P
Post by: fiatmaluch126 on July 26, 2011, 08:05:01 AM
Mines a standard Darrell, And i've finally had my floor plated! No more floods in car!   :P
