Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Kipster on June 10, 2011, 08:11:13 PM
Each time i change gear i hear a clunk from the R/H side. This sound is FAR WORSE when my wife drives the car..... (not so confused).
Obviously wear somewhere, can anyone point me in the right direction please.
Hi, try checking under rear of car, 4 bolts going into flexible joint to wheel, make sure they're tight also check left side while your there. Bolt size 13mm spanner needed
Thanks i have checked them, they are tight as a Badgers
sounds like the gearbox or engine could be knocking on the body work somewhere could mean that the gearbox mounts are shot or need resetting or the engine mount is on its way out. have a look to see if you can see any marks where it may be striking. another thing is if you have fitted an aftermarket exhaust (bigger tail pipe) it may be rocking and striking the rear panel.
Thanks for that. Will look tomorrow 8).
