Fiat 126 Chat => Fiat 126 Chat => Topic started by: skelz on June 06, 2011, 12:31:37 PM
borrowed a wiz bang laser thermometer from work today and thought I would check out my engine temps Start Temps
Exhaust 22c
Rocker Cover (near oil cap) 22c
Block 22c
exhaust elbow 22c
After idling1 minute
Exhaust 205c
Rocker Cover (near oil cap) 26c
Block 30c
exhaust elbow 190c
After 5 min idling
Exhaust 235c
Rocker Cover (near oil cap) 50c
Block 45c
exhaust elbow 223c
After 10 minutes (gentle driving 60km/h)
Exhaust 355c
Rocker Cover (near oil cap) 91c
Block 102c
exhaust elbow 398c
at 20mins (10 gentle 10 at 100km/h)
Exhaust 426c
Rocker Cover (near oil cap) 116c
Block 121c
exhaust elbow 502
2 mins after stopping
Exhaust 300c
Rocker Cover (near oil cap) 114c
Block 108c
exhaust elbow 304
5 mins after stopping
Exhaust 137cc
Rocker Cover (near oil cap) 108c
Block 102c
exhaust elbow 231
10min after stopping
Exhaust 102c
Rocker Cover (near oil cap) 100c
Block 90c
exhaust elbow 179
40mins after stopping
Exhaust 40c
Rocker Cover (near oil cap) 60c
Block 61c
exhaust elbow 61
Now I find that information quite interesting and the particular one I was looking at was the exhaust elbow as I have found it impossible to keep them looking good . I just checked out the high temperature spay paint that I used on mine. It stayed on for a while but not much left 6 months on. The can says that it is good for 650 C >:(
Check the temp of the coil once run for a while I was thinking about putting a cover over it too shield it from the heat.
I was surprised how hot thoes elbows got!! The suspension spring gets just as hot.
Odd that your rocker cover stays cooler than the block. Rocker cover is connected to the head so you'd expect it to get warm :$
Mine the rocker runs at about 110 degrees C but the block runs at about 80 it gets warmer on long runs.
I started a topic ages back mentioning the high temp of exhausts, you got the gift of the gab coz they take notice of yours :P
Oil temp rarely gets above 80 but that might be due to an alloy big volume sump
http://club126uk.co.uk/smf/index.php?topic=5304.0
Assuming you are using 1 of those laser pointer things with a small red dot , what part of the exhaust were you testing out of interest ?
I have just 2 packed my whole engine and covers so will be interesting to see how t goes , didnt expect it would get that hot to be honest.
Well I have a VDO disptick replacement temp sensor from the old beetles fitted to my Niki. the temperature this reads is between 100 to 120 degrees C once the engine has warmed up. I generally find that the engine only really cools itself down from these with extended idling. Normally chugging around the city it will read around 100, but once you open it up for higher speed driving or hill climbs it will climb and hold around 120. Reading on the beetle forums, this is pretty much normal for an aircooled motor being measured in this way.
yeah i was using the red dot laser thermometer.....i was measuring near the top bend of the pipe nearest to the rear
Yup got you , thought you meant like the muffler itself :o
I dit a measurement too, but with a thermal imaging camera:
Wow, I want one, how much did it cost?
what? the measurement or the camera (they are not cheap)?
How much are the cameras? and dont the cameras have the measurement built-in?
That really is cool 8) in a hot sort of way :$
MY Kodak Brownie Box Camera wont do that.
Thank you for the useful and interesting thread :thumbup
I found this very interesting, thanks. It explains the blisters i get on my hands when impatiently meddling with the distributor before allowing the engine to cool.
It also shows that the front brakes take most the load which explains why modern cars have huge brakes up front, and a token to the rear.
What I have suspected for a while is what is confirmed by your pictures that the hot air pretty much stays on the right side of the engine bay.
This in my opinion, would mean that any air drawn through the right side of the air duct of a 126 would have been pre-heated :o
I saw Lad's machine a few years back which had a slightly bigger air duct fitted only to the left side which now makes perfect sense and the right duct was left as a release for the hot air on the right side of the engine bay...
I think a plan is afoot ;)
That's the ugly truth...
Here comes a good solution, like the one you describe:
I want that one ;D
Home made or does someone sell a kit?
what sort of temperature should my aircooled barbecue run at?
All depends on the item being cooked.
I'd imagine steak and pork to be similar. Sausages and chicken a little lower..
Haggis needs to get alot hotter :$
cheers mate if i turn the wheels round to make it look a bit more street will it alter the way the food cooks?
You guys just bought tears to my eyes :D :D
Street....No mate, from experience this may add stability to the barbaque however the best barby should be a permanent fixture, level to stop the sausages and haggis rolling off.
Even better would be a chimney installed to stop the smoke blowing about bringing tears to the eyes.
I expect more street cooking would require a licence of some sort :$
