For Sale & Wanted => Ebay Bits & Pieces => Topic started by: Amateb8 on June 01, 2011, 10:59:08 PM
Has anyone installed rear disc brakes on a 126? The existing drum brake configuration is sufficient to stop the car but always useful to convert the front drums to disc brakes. But the rear as well?
http://cgi.ebay.co.uk/Fiat-126-Rear-Disc-Brake-Kit-New-/300218369674?pt=Vintage_Car_Truck_Parts_Accessories&hash=item45e668c68a
Wouldn't say no if I could adjust brake balance inside the car.
In winter my disc brake front-end can lock-up easily which would be nice to move the balance to the rear a bit to try avoid this, but would disc rears lock up :-
I am in the middle of gathering the components to convert the rear to discs. Have addapter plates from TRS, I think, plus a set of calipers off a polense ??? problem is getting spares for the old calipers. Been down the breakers to see what is available, just to decide which set to go for. TRS sold a balance adjuster which was placed in the cab to allow adjustment, dont have one yet. I will keep you informed of my progress.
has any one sussed out a home brew kit for these.
on the trike scene a lot of folk use robin reliant axels, (drum rear brake), and they use a mix of golf mk1/2/3 calipers and nova disc with bolt on/weld on caliper mounting.
wondered if any one had sorted a brekers yard marrage, rather than the £350/450 kits i seen on ebay.
the golf rears have a work gear handbrake biult in, thats what makes them popular. 8)
