Fiat 126 Chat => Fiat 126 Chat => Topic started by: jabeoo1 on May 11, 2011, 10:17:25 PM
Title: Pertronix Electronic Ignition Kit MR122EVO 500/126
Post by: jabeoo1 on May 11, 2011, 10:17:25 PM
Firstly I noticed this as an old topic so thought I would update it and see if anyone has experience of this newer kit
My distributer cap/points/rotor arm are what seem like the major pain in my fiat 126's ass.  Is it just me or is it the same for everyone who owns older cars? Every few months the first sign of a small occasional misfire creeps in.  This is followed at any point in the next month by a decline over about 20 miles to an engine having the human equivalent to a heart attack.
Any up to date thoughts on the Pertronix?
I have spoken to these guys today and they have full kits with coil for £180 including VAT.  The new system is apparently a lot better than the earlier designs.  I asked outright what teething problems they had so far.  They replied that they have yet to hear from anyone with a problem.
I am considering it but really wanted to get some up to date info direct from users.......Anyone out there thinking the same as me??????
Title: Re: Pertronix Electronic Ignition Kit MR122EVO 500/126
Post by: skoda_norman on May 11, 2011, 10:48:23 PM
Points and condensors can work really but they can also been massively inaccurate and unreliable. I'd love to know more about this kit as it's alot of money to spend on something not yet proven to work.
Post by: Pete126 on May 11, 2011, 11:58:25 PM
Some members have fitted electronic ignition systems to there 500/126's with mixed results some swear by them and others Swear at them and bin them ;D I don't know if anyone has fitted the petronix and it would be interesting to here from them.
I'm OldSchool and stick with the conventional setup its cheap and easy to fix, one of the best mods you can do is to upgrade your ignition system to the later twin spark system, (where the plug leads come directly from the coil instead of the distributor cap) I carry a spare Twin Spark coil, Points, Plugs and condenser in the car, But never had to change the originals (which only takes a few minutes) or reset the static timing in the last 4500 miles, there's nothing else to go wrong with the ignition system and its allot cheaper than the electronic ignition kits, The only problem I had a couple of years ago my 126 it had an occasional misfire/stumble when ticking over, I replaced the condenser and the problem went away, the condenser must have been breaking down internally, Out of all the components on a conventional ignition system the condenser is the weakest link.
Post by: Darrell on May 12, 2011, 05:36:11 PM
I've done thousands of miles on the same set of points. Lube the cam so the bacolite thing doesnt wear down.
Electronic ignition has to be more reliable long term, just I found a well known make whose name is numerical, advanced the ignition too much which lead to overheating and my cylinder head developing cracks between the valves.
I am giving it another go as it was an expensive item however have set the fire point at idle on TDC. Somehow it seems to run ok, not done a long run yet :$
Post by: dajwid on May 14, 2011, 07:59:41 PM
Pete, the system you have is driving me mad, any ideas?
I have tried everything, Timing is ok, points gap, Ok, spark, Ok fuel is Ok, carb is Ok (3 tried).
I have always had the old system but Beryl has twin spark type.
Should there be 2 Condensers? I was told by a specialist (Polish car tinkerer) :$ There should be 2. i only have one on the distributor.
I must say it has run on and off, but really rough.
Any ideas anyone.
I am thinking of buying a Beetle, help me before I go over to the dark side. ;D
Post by: dajwid on May 14, 2011, 09:56:33 PM
Mmmm so condenser is right.
First it was running but lumpy (well worse than a normal 126 anyway). then stalling when warm.
Timing is spot on (static), plugs new (good spark). Pumping Fuel, Carb is a rebuilt carb (tried others). I now can't even get the car to run at all.
looks like it is timing but it is spot on, can't check with timing light as cant get it run.
Will buy another set of points and condenser again, but any ideas would be great.
Post by: Pete126 on May 14, 2011, 09:57:58 PM
Hi David, What it actually doing?
There should only be 1 Condenser. Screwed on the side of the distributor, are you sure its an ignition fault?  If the engine is running try moving the distributor and see if you can smooth out the idle. If it does check the ignition timing again.
(http://club126uk.co.uk/smf/index.php?action=dlattach;topic=5838.0;attach=4213;image)
