Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: mcbonio on March 22, 2011, 04:48:03 PM
I know this has been covered, but i'd like to go over it again. I'm scouring around for my own little 126.. Meanwhile, I'm looking into how an engine replacement would work out..
I've seen these on flea bay..
http://cgi.ebay.co.uk/Fiat-Cinquecento-899cc-R-Reg-Engine-/280540499645?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4151844ebd
http://cgi.ebay.co.uk/FIAT-PANDA-SEICENTO-CINQ-900cc-8V-ENGINE-GOOD-RUNNER-/360298141670?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item53e37157e6
I'm a fairly competent mechanic, but have never done an engine swap before.. I have 2 questions,
1. How would I mount these engines inside the 126?
2. Would these bolt straight on the stock gear box or require an adapter?
Thanks guys, you all have been amazing in answering my questions before..!
In the UK getting any of the mods registered is tough VERY tough. Look into UK regs before you even start along this road. Unless you want a track only toy of course.
I've been on it all day, I'm thinking now that an engine swap isn't worth the hastle. The real way to get it through, it from a registered mechanic, engineers report, and then the insurance is high as its a modded car...
Ok, back to my original plan... soop up the original 650cc power plant..!! Wooo
What are the essential good modifications for the 650cc and 700cc BIS engine?
More tuning bits for Aircooled. Power is limited to your budget. Warning it can get VERY expensive.
Lots of posts on here about tuning
Good luck in your search for a 126 as I think that is the first hurdle you need to overcome and get a car on the road. As Dajwid says the air cooled cars have the most potential for tuning ( no offence to the water boys ). If you are a "fairly competent mechanic" then most upgrades can be carried out over a weekend wether it be an engine change or upgrade, suspension lowering or brake upgrade. One to two thousand pounds on parts will put a bit more Zip in your motor but I recently spoke to a guy who spent over £14,000 on a 500 rebuild (not the most expensive one I know of) and most of that was on the mechanics so same as the 126. So as Cilla (and Dajwid) would say you can spend a "lora , lora money" on these little motors. Whilst you are car hunting I would suggest that you look back at a lot of the stuff that has been said on this forum about tuning and you can also check out the specialist suppliers on the net to get an idea of prices & how far you might like to go [-/
Cheers for the info rusty. Some very nice folk on this site.!
I say I am a fairly competent mechanic, I've done all the upgrades on my current (VW Bora) and past cars. Brakes, ABS, suspension, bodywork, some engine work - head gasket, .. never rebuilt an engine yet, but looking forward to it if need be, I miss tinkering around on the weekends.. getting away from the missus and relentless kids parties...!!
So yeah, I'm on the lookout for a white 126 WC or BIS. Don't have a fortune to spend at the moment, would rather find one £500 to £1,000 - , something that needs work but not a total rebuild of everything if you know what I mean and then that become my daily driver. So with my budget it will probably be a BIS... Can't wait..! :D
You should get a solid Aircooled for that money. Bodywork is most Important. mechanical problems are not normally too tough to sort out. (I'm certainly no mechanic)
Yeah I want an Aircooled really, Anyone selling a white one?
