Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: Chris Lakin on December 27, 2005, 01:12:40 AM
you may think this is a daft question, i was thinking about this the other day, but why hasnt a super mechanic in poland fitted a turbo to their 126 yet?? ive never seen one.
i know the fuel pump etc probably would be able to keep up, but am i right in thinking that turbos can be used on cars with carbs?
You could turbo one, you would need to find a very small turbo tho. Probably one off a 600cc japanese car.
You can use a carb, Wouldent use the standard one tho :) use an electric fuel pump aswell
The main problem i see in it is the cooling system. Obviously aircooled isnt the best to start with and not easy to uprate and the BIS is way too unrelyable. If it blows head gaskets at standard level of tune its not going to last 5mins with a turbo!
Fitting one would be easy but there are relyability issues!
doubt the aircooled engine would handle it either. werent Porsche 911 turbos aircooled? certainly the good old gearbox and driveshafts would die too!
What about a Smart car turbo, or even a Reliant Robin Turbo?
www.monkeyrun.co.uk The owner of the website has built a 120cc Honda Dax, and has fitted a lawn mower Turbo.
http://www.btinternet.com/%7Egoosegog/turbodax.htm
John
thats a quality link, great project.
"Oh and in the end it didn't really work anyway! "
As if he did all that work and it dosent work! :D
wow, loads of info on that one!!! that site is nice to learn from!! That bike is using a 500 carb!
could you imagine if a small turbo was manufactuired for a 126, even if it was a very small one, the smaller the faster acceleration and bigger the turbo the high top speed you can gain.
all sounds very nice but Barry & Slater are right, far to un reliable at present, the porsches used aircooled engine untill mid 80's i believe. Interesting subject though.
I want to have a go now! :roll:
i was thinking of making some alloy cylinder barrels for a 650 engine, like the porkas have. Its not very difficult and you could increse the amount of fins or something to make them run a bit cooler.
My dad gets alot of work from a guy who builds aircooled porka motors and i keep comparing the bits with a fiat motor. They are a very simlar design
hi,i know it sounds cruel and defeats the object,but it would be 10 times easier to ditch the engine and get another(there are ways and means to fit one)i always thought that you needed a low compression engine ,and a decent cooling system.other wise melt down would happen.
Your probably right but it kinda takes the fun out of it relly! :P
Your right about compression but when i think about it 126s had a low compession engine to start with (early ones even lower!!) so you would probably get away with it. Even if it becomes an issue its easy to lower it a bit more with a little grinding of the head.
lol,wouldnt early low compression ones melt down.they are only air cooled.wouldnt they need oil coolers,intercoolers and at least a very good air circulation?
they would sell destruct,they would need liquid cooling.
suppose it would depend on how much boost you gave it.
Supercharging may be a more sensible option.
lol,it would munch through gearboxeslike my granny does dentures,been there bfore too expensive.
I remember reading an arlicle a few years ago about a guy turbo charging a 2cv.The first one went on fire(the standard one's did'nt need any help in that department I know this from cruel experience)but the second one went like the scalded pussy.Another alternative was to fit the Citroen gs engine four cylinders and 1200cc fits straight in (more or less) :D
I'm surprised at you Chris, I have a turbo engine well underway (I had told you about it previously)
When you come on msn I'll forward you some pics with a proper explanation of all the pitfalls and problems and how I have got around them
That site with the Dax is a really good read, interesting stuff. You can do all sorts of buggery with a little engine . . . it rocks
The only other type of engine I would consider putting in a 126 is a another aircooled lump, 2 cylinder of course. Thats their main character, a 126 with a normal engine would be dull :wink: There are plenty of good old bike engines that would do, but its cooling them. Yamaha XS650, that would be ace or a BMW boxer lump? Once saw an old british Sunbeam bike with a 126 engine in it with the sunbeams box, it fitted so well and its amazing just how tiny the engine is once everything is taken off. It had a SU carb which is probably a good thing too! Turbos, nah! Dont even consider using anything made for or by Smart... it only lasts a few minutes!
(http://www.fiat126.co.uk/images/turbo1.jpg)
(http://www.fiat126.co.uk/images/turbo2.jpg)
John Bitmeads (Darkhorse) 126 aircooled turbo project! He asked me to post these pics up for him.
im shocked its been done!!! well done John and thanks for sharing it with us! :lol:
regards,
hi,well darkhorse knows his stuff. :wink: nice to see somebody thats a little diffrent.job well done.when can i test pilot it? :lol:
me first toz!!!! :lol:
Intesting bit of kit :D
My God that's neat,and it is'nt spread out like a load of spagetti(excuse the pun) :D.John have you strengthened the bottom end or anything?
Thanks for the interest all.
The whole idea of this project is to make a bolt-on system that doesn't require any modifications to the engine in the slightest, so in answer to your question Paul, the bottom end is standard.
I will explain a few pointers about what and why I have gone this route:
Firstly these delightful little engines are prone to shearing the crank in half when over revved (a common problem once they have been tuned)
so I decided that I wanted to produce more torque, and not worry about a horsepower increase, this would make the engine far more tractable and user friendly. In turn, I needed to find a turbo that would spin up quickly at lower RPM - the obvious choice is the smallest diesel turbo unit available to me (top secret at the mo!!). Diesel turbos have a different vein angle to petrol turbos, hence the different points of boost.
Secondly, I didn't want to have to muck about putting oil lines in, especially as the twin has only got a centrifugal oil filter, so the plan was always to have its own oil supply, cooler, filter and of course, electric pump all running with a high spec synthetic oil - all fitted on a supporting plate making fitting and removal extremely easy and fast.
Thirdly, because I wasn't aiming for a performance turbo I have opted for a suck-through system. like the old style drag bikes used to use (the carb is before the turbo not after). Another reason for this is I won't have to go to ridiculous lengthes to equalize the pressure in the fuel bowl and create more complications with jetting.
The carb I have chosen is a 650 single cylinder bike carb (huge 40mm).
Because it is sat in front of the turbo, the metering of the fuel is going to be simpler because it will still suck an equal amount of fuel / air mixture. The only negative point, with regards its positioning, is a small amount of fuel de-vapourising as its spun out by the turbo, but this shouldn't cause me any problems as its a relatively low revving engine.
So with all my aims here fairly well complete I hope to have a self-contained turbo unit that can be easily fitted to a standard engine, removed and then back to a stock engine again in a matter of minutes (quite literally).
Thanks once again for your flattering comments, they are much appreciated
Sounds like you thought about tht a fiar bit then, good stuff.
what performance increase do you see then?
Now you've got me thinking John.What about a turbo from an x type jaguer diesel,they use a variable pitch vains in the turbo working off a vacuum diaphram (on the early ones).
Now thats interesting Paul, I had no idea although the turbo unit is likely to be a bit to large to start with but I like your way of thinking :cool:
Actually to tell you the truth John it's quite a compact unit plus,the x type diesel is of only 2 or 2.2 litre in capacity (and it's a four cylinder,tch).On the car it give's boost right through the rev range (no lag) quite smart eh?
I really am intruiged by the idea of one of these units now ;)
Might be the next plan for the bis version :D
I was intouch with a guy called martin igelmann last spring about using a Citoen Visa engine (34 BHP) - this is becoming a fairly popular upgrade on the continent. he had posted on the 500 club website with some details. I couldn't find an engine in the UK. They cost a lowly €130 or so in France, though there is a €420 conversion kit required so its not going to happen for me soon. The exhausts are crafted from a Honda 600cc but most apparently use Harley "shotgun" exhausts. I think it looks the business in a 500 snd would be equally at home in a 126. Just hope the heater still works!
500 club post:
http://www.fiat500club.org.uk/boards/fiat500/index.cgi?read=15175
(http://img141.exs.cx/img141/3674/fi50004kl8sr.jpg)
(http://img210.exs.cx/img210/7088/fi50001kl6dh.jpg)
Forgot to mention... the Visa engine has no turbo - the turbo engine just jogged my memory...
i know somone who has just sold a visa for £250!
but Pual, why would someone lump a visa engine in? when they could tune a 650cc engine? and get equal bhp?
looks like an awesome conversion, i have a honda cx500 bike. its been stood in the garage for the last 6yrs and allas the rust worms have started eating the frame i have been toying with the idea of converting it to fit in my 126bis my idea is to do as much of the conversion out of the car so i can still use it, i think it will just do the job, although the honda cx500 is only 496cc, 80deg' vtwin, water cooled, 4 valves per cyl its quite a small unit and very reliable, its found its way into many kit cars like the morgan look alikes and packs quite a bit of punch 50hp/38kw and a flat torque curve between 3000 to7000 rpm maxium torque @ 7000rpm 32ft-lb/43nm which should be kind to the gear box. i was going to use the bike gearbox until i thought, no reverse gear as like any other conversion it won't be easy as iv'e found out over the years. if anyone has done a conversion of this type or can give any helpful tips it would be much appreciated
Hello Paul,the reason your having trouble getting one of those engines is aircooled visa's are very thin on the ground.Same engine is in the 2cv,dyane etc I know a guy how has at least a dozen of them in his shed :D .Give me a shout if you want any more info.Cheers,Paul
I am so impressed with that conversion, it looks so damn neat.
The czech 500's (steyr-puch) had a horizontal flat opposed twin so it seems a sensible conversion to just go a bit bigger!!
well done for including that Paul
The CX500 engine in a BIS sounds brilliant, true it is a great little lump.. what about a CX650 Turbo though!?!? Now that would be awseome :lol:
Just looked at the pic of the aircooled froggie engine in the 500, one thought... how the helll do you get to the points? Its bad enough on a 2CV! For those that dont know, they are in a box behind the fan! Really nice job when they have closed up on a dark, wet and windy night. If you really wanted one there are loads of 2CV specialists out there.
It has no points. It has electronic ignition as standard though it seems that needs modding to be reliable. The fiat's ignition is sh*te and the cause of 95% of my problems. Electronic ignition for the 126 is, like all 500/126 tuning parts, over-priced.
Other plus points for the citroen Visa engine:
- Its 35bhp for about £400, that's before any tuning...
- *I think* the engine is essentially a steyr puch that citroen have developed, so as darkhorse said, its not entirely out of place in a baby Fiat. Citroen's early engine for the 2cv was less than pointless - pushing was more effective (9bhp I think).
- As a flat twin more of the power will be reaching the wheels, less will be throwing the engine about
- Its got nearly 30% more grunt than a stock 126 engine, still leaves a 126/Panda 30 head and carb standing
- I'm not sure on this bit - my stock 126 engines start to top-out at around 3500 rpm (stock cam - FSM should do better) - the citroen will manage higher rpm (need to check this) - if true then the top speed will go way up without upgrading the gearbox. In my 500 (stock 126 652cc and g/box) I run out of revs at about 72mph (probably could go higher but the engine is screaming at 75mph). Martin reckons his 500/Visa is good for 80mph+ (My 126 aircooler runs out of power before it runs out of revs thanks to the biscuit tin aerodynamics and extra weight)
- torque
- it just looks the business
- always better to scrap a citroen for an engine than a Fiat!
down sides:
- ground clearance
- will get snubbed by purists (maybe that's an advantage?)
- will have to start hanging round 2cv drivers for the science
the 2cv/dyanne had an earlier 600cc flat twin, which managed to reach an impressive 32bhp, but most were more like 28bhp so no point in putting one in without tuning it. 2cv racers often use a tuned Visa engine.
Darkhorse - there's a few oblique comments about turbos on the 500 club board. I think one problem is the cylinder arrangement on the Fiat which makes it hard to spin up a turbo (both cylinders move in unison). The other is keeping the cyinders and head cool - keen to see how well yours works.
Off on another tangent here (still inspired by the turbo though...) Stock aircooled 126 engine has the large cooling fan forcing air down its throat, but a cruddy paper filter choking it. A popular mod is to block the air filter and suck air through a less restrictive after market filter in the engine compartment. This reduces the restriction, but loses the thrust of the fan and means sucking in hot air (not good) Has anyone come across a decent replacement for the paper filter so there is still the benefit of the thrust/cold air from the fan?
interesting, I never knew that Visa engine wasnt a normal 2CV lump, glad to see they dumped the points system as it was a real pig to get to them! I have nowt against 2CVs, they are very good for what they do, and that engine will really rev hard, but it hasnt the character of the 126 engine :wink: Interesting that you find the Fiat ignition crap, its been in use for years and if set up right will be very reliable, its so simple I cant understand anyone having problems. Think you will find French electrics to be troublesome though :shock: there is an aftermarket electronic kit for the 2CV called 123 ignition but opinions are divided on its reliabilty too. still, is the most interesting engine convrsion I have seen, at least its aircooled and a twin, should be cool :lol:
Aside from the points tendency to close on three lane roundabouts or in pitch darkness/rain, the condensors to fry or the cap to short out, the ignition is fine. The Polish square twin coils are solid though - and get rid of the cap and rotor.
Not just a Fiat problem - I'd guess that most roadside stops in older cars would be ignition trouble (or maybe cooling for steam-driven cars like the BIS?).
that conversion is sweet . . . ive always fancied doing something like that.
ever since i saw a mini on the telly with 2! yammy r1 engines in . . . .wow
http://cgi.ebay.co.uk/RENAULT-MASTER-2-5-dci-TURBO-TURBOCHARGER_W0QQitemZ4600968590QQcategoryZ10410QQrdZ1QQcmdZViewItem
There's a place called Silly CVs that turbo-charged a Citroen 2cv (with large barrels - 650cc) which racked up 68bhp..They may have some useful info for the attempt on a 126 engine. Their site mentions racing 2cvs with fuel injected 602cc engines racing at 120mph, which made me wonder whether injection was a more viable direction?
http://www.sillycvs.co.uk/02LastProjectCar.htm#
Edit: Just spotted their latest project for those of thinking of bike engine conversions (and for those with a deathwish) - 160bhp Honda powered 2cv...
http://www.sillycvs.co.uk/04latestProjectCar.htm
My '95 runs's on a dizzyless ignition and so far(touch wood) no prob's.The bloody thing goe's like a rocket (well 126 engined rocket) had it at 78 but ran out of duel carrageway. :lol:
blimey paul 78? going down bennevis? or on a level road? :lol:
so your aircooled has the same ignition as the BIS?
nigel (Hudsonhenry) has this motor bike ignition, its a tiny little black box in his 500, he did explain to me more about it, but i cant remember.
The bis has a dizzy Chris.Mine has no dizzy at all even the hole where it used to be mounted has been deleted.No it was a straight carriageway between Hollywood and Belfast,ran out of road at 78mph :lol: :lol: im so chuffed with the way the wee buzz box is going.(hope I have'nt scudded myself) :roll:
