Fiat 126 Chat => Fiat 126 Chat => Topic started by: kitten75 on January 30, 2011, 03:21:53 PM
Title: Help!!!
Post by: kitten75 on January 30, 2011, 03:21:53 PM
First time since I bought it, it hasn't started...tried it a few times (probably too many) but just wouldn't start.  It's been a bit temperamental lately but has always started after 4 or 5 attempts but not today.  Fired up once but didn't catch properly and then just cut out again...
It's due MOT this week so was going to take it into garage anyway - don't particulary want to have to get garage to come and collect it!!  Any ideas ?  It was turning for a few times but then just started clicking...
Mhairi
Title: Re: Help!!!
Post by: dajwid on January 30, 2011, 03:27:17 PM
Battery, bad earth.
Title: Re: Help!!!
Post by: nrg19uk on January 30, 2011, 03:51:57 PM
Flat battery! The cold kills batterys
Title: Re: Help!!!
Post by: thepuddlejumper on January 30, 2011, 04:27:26 PM
sounds like you need to charge the battery
Title: Re: Help!!!
Post by: Rusty's Uncle on January 30, 2011, 06:14:08 PM
I would check to see if the contact breaker points are opening properly. They tend to close up with wear or if they are not fully tightened which would account for the poor running as it throws out the ignition timing & gives you poor starting & tickover. With a full battery on starting the engine can turn fast enough to just flick the points open to get you going & will run fairly well on medium to high revs for a while. I would also check the tension on the fan belt.
If it is the points they could be reset in a couple of mins & you could jump or bump start the car to recharge the battery  [-/
Title: Re: Help!!!
Post by: Amateb8 on February 01, 2011, 10:08:14 PM
When was the last time the car had a full service?
Title: Re: Help!!!
Post by: K666STW on February 02, 2011, 04:20:56 PM
I had identical symptoms recently and it was the points. Quick adjustment of the gap and away we went. :)
Title: Re: Help!!!
Post by: kitten75 on February 02, 2011, 04:56:45 PM
think it may well be points as tried it again yesterday and it fired up first time but then cut out straight away and wouldn't fire up again...
Not had full service done it since I bought it in July - it's due MOT next week so will get a service done at the same time...
cheers
Mhairi
Title: Re: Help!!!
Post by: Amateb8 on February 02, 2011, 10:05:46 PM
It is worth giving the car a full service i.e. change plugs, points, fuel filter etc. and not just the bits that malfunction. You might as well get the front suspension greased, brakes and gearbox oil checked. KChange oil? Do all this if you can for peace of mind. Keep a record of when the full service was done and what was replaced. Keep the reciepts as part of the car's documentation.
Good luck on the MoT!!!!!
