Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: massa on January 09, 2011, 07:26:16 PM
Title: fuel
Post by: massa on January 09, 2011, 07:26:16 PM
what fuel do the majority use i have been putting v power in is that required or is standard unleaded ok  equally ignition timing is it best to adjust depending what fuel ? thanks again lads dave
Title: Re: fuel
Post by: skelz on January 10, 2011, 01:09:28 AM
I was thinking the same thing recently !.. I have heard that the premium fuels burn hotter (than normal fuel) and was thinking that with an aircooled engine this might not be a good thing..
I am sure the guy with me experience will be able to steer us on the right track
Title: Re: fuel
Post by: fiat126.com.pl on January 10, 2011, 10:50:35 AM
Hi Massa.
126p engine was designed for leaded fuel. Important is the number of octane. Between 70.80 - these heads were designed for 90 octane number, and from 90 - to 95 octane.
Recent models have heads aligned on unleaded fuel.
In my opinion, more fuel octane does not significantly improve engine performance, and only help to accelerate engine wear (burn the valves).
Title: Re: fuel
Post by: massa on January 10, 2011, 09:30:57 PM
ye thanks artur was starting to think that, normal unleaded it is then you always think that your doing good by putting good stuff in not always so eh thanks again
Title: Re: fuel
Post by: Draigflag on January 10, 2011, 10:13:12 PM
BIS can run on UL though can't it?
Title: Re: fuel
Post by: massa on January 15, 2011, 08:10:46 PM
ye i just thought i was being kind to the engine by putting in a better grade of juice by what i can gather they were meant to run on normal unleaded thanks
Title: Re: fuel
Post by: Darrell on January 15, 2011, 08:21:32 PM
Been running my aircooled for 3 years now on unleaded and I do loads of mileage.
Tried the fancy stuff for a while but noticed no diference.
(I test her performance on a hill) If she makes 40 by the top she's about right and the fancy stuff never got me to the top of the hill any quicker so I'm thinking it's a con :P
Title: Re: fuel
Post by: Amateb8 on January 20, 2011, 09:50:43 PM
The 126 Bis runs on unleaded fuel (UL). Using premium unleaded rather than the regular UL does not affect the performance of the car.
