Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: Darrell on December 10, 2010, 04:20:29 PM
The ones the drive shafts bolt to (with rubber inside)
I've been through so many sets now, I could sell them as paperweights!
On my last set now which Lad gave me but I had an idea.
How about removing the rubber and filling them with this:
http://cgi.ebay.co.uk/EasyFlo-95-Polyurethane-Liquid-Plastic-Casting-1Kg-/220502359008?pt=UK_Crafts_Other_Crafts_EH&hash=item3356f6fbe0
Any thoughts?
PS I know about the CV conversion option alas that conservatory Gilly wants has haulted play on stuff like that :-X
I know what you mean but it's something you have to live with unfortunatly (i had to change the half axle rubber boot after 50-60kms ! ), but i'd rather pay a bit more for a 126 part and know that it's good than have to change it every 1000 kms...
thats weird that they wear out so quickly. the only time i had that happen was when my car got stolen and i drove it home with the rear right wheel sitting at a very bad angle - about 30deg toe out & 20deg pos camber. I could smell the rubber as i was driving.
Did the same as u Dazza and had to change them again (ie - fix the control arm - but not in 5 hrs)
Got the poos and ordered a new control arm and seems to have solved the problem. I dont think everything bolted up as it should have after i "straightened" it.
So the only advice i can give is to check that everything runs true after the repair.
Oh yeah just remebered - check that the spring and washer are seated correctly. The shaft can pound this area with suspension movement
Yeah the straitened one I changed when I did the repair.
But now I see the other side !$$%%***!!! one is all floppy!
