Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: f40fanatic on December 08, 2010, 09:35:19 PM
Hello!
i am having trouble with my bis, i recently changed the exhaust and me and a mate did a brilliant job of fitting a new one!, but when it came to hearing the engine run, it wouldnt turn over :s
when i turn the key to turn the car on, i get a click from the solonoid but the starter motor wont turn.
we had a good root around under the car and couldnt see any loose wires, and the car was starting fine up until we changed the exhaust, we did have to giggle the old exhaust off, i dont know if we knocked anything or what.
its going to a garage on saturday but i wondered if anyone had any ideas??/?
thanks, Dave.
that sounds like you havent got enough juice in the battery try charging the battery or try jumpin it off another car see if that starts it.
ash
It could be the battery or the solenoid is starting to play up. Annoyingly, it happens to me occassionally.
isnt there an earth strap about there somewhere on the bis? might be an earthing problem?
thanks anyway guys but ive fixed it, i got told by many people to hit the starter motor with a hammer, it actually worked, it was just the starter that was jammed! looks like jeremey clarkson's way of fixing things works occasionally!! :)
You may be right. When it happened to me a few days ago, I thought it was the freezing temperature that stopped the starter from turning. Like you, I just heard a click but the engine did not turn. I thought there was electricity going to the soleniod evident in the clicking sound. A quick push start and the problem seemed to have gone away. If it happens again, if I can't coax passers-by into pushing the car, I shall give the starter motor a beating with a hammer!
hehe, it works!
