Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: neilW on November 30, 2010, 09:35:00 PM
Title: My engine wont turn over
Post by: neilW on November 30, 2010, 09:35:00 PM
Hi I have recently been getting problems with my BIS. Its been back firing through the car and the exhaust. Ive cleaned out the fuel filter and carb but cant get it to turn over any more?  ???
The spark plugs were dry and sooty and have now cleaned them.
Does anyone have any suggestions as to what could be the problem??
Title: Re: My engine wont turn over
Post by: Rusty's Uncle on December 01, 2010, 07:10:45 AM
Are you saying that the engine will not fire or that it is physicaly seized  ???
Post by: neilW on December 01, 2010, 10:18:23 AM
it ticks over, i.e sounds like its about to start but just wont fire up?
Post by: Rusty's Uncle on December 01, 2010, 01:03:30 PM
OK , slightly clearer now , the car will "TURN" over but will not fire so therefore will not run or "TICK" over. So was the car running OK before you hit this problem  ???
Post by: neilW on December 01, 2010, 01:16:43 PM
it started to chug and loose power although the engine still ran.
It then started back firing through the carb and exhaust.
but yeah only the day before it was running a dream. usually takes around 10 seconds of persuasion to start up in the mornings.
Post by: Rusty's Uncle on December 01, 2010, 03:51:15 PM
I think that I would start with fitting a new condenser  [-/
Post by: neilW on December 02, 2010, 10:39:32 AM
the wasted spark coil right? I ordered one of these yesterday.
Post by: Darrell on December 02, 2010, 10:45:34 PM
The coil on the BIS looks like a black round-ish thing normally bolted to the right forward part of the engine compartment. Out of if come the two HT lead (big thick wires) to the spark plugs.
The condenser is a small roundish silver piece screwed to the side of the distributor.
The distributor has a black cover with two screws on it and is found centre of the engine at the rear of the engine. The distributor has a single wire coming out of it and has a small hose coming from it.
Inside the distributor you will find the points which have to be adjusted to open to a specific amount (cant remember off the top of my head what that is now but less than 1mm)
First port of call in my opinion would be to check the points are indeed opening to that specified amount which can be measured with a feeler gauge probably halfrauds will have a set.
Specifications and instructions are available on this fine website in the haynes manuals which are available to subscribing members. The subscription is a donation of how much you decide ;)
I strongly suggest doing this as the manual is so valueable and it's a mighty fine website with loads of help from many experienced people on it  [-/
I hope I am not over simplifying my descriptions but thought it best to be as clear and simple as possible. :oops:
Post by: Alex on December 03, 2010, 12:50:48 PM
also remember to make sure you adjust the points when the distributor is in the correct position.
the gaps are as follows:
Marelli 0.37-0.43
Zelmot 0.47-0.55
Post by: K666STW on December 05, 2010, 03:17:20 PM
I was having the same problem the other day. 1 of the screws that attach the condenser to the distributor was loose and not earthing the points properly. Tightened it up and the car started running braw again.
