Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: smallcox on November 27, 2010, 05:52:03 PM
Man is this giving me a headache,
I contacted a couple off bearing suppliers as i wish to upgrade the rear bearing, The type i'am after is like the front one which does not have a oil groove in the middle. By removing this groove in the bearing the loading capacity so i'm told will increase by 80%.
I require a bush type bearing aluminum/tin but am struggling to optain one >:(
Any idears out there, and no Darrell I will not be fitting roller bearings :oops:
I did hear off ali bearings fitted on some advert here to a 126 but have had no joy finding out more.
Thanks Smallcox
Now look here Slamcolx ;D
There ain't gonna be any aluminium in those bearings. There may be some antimony in there & that is not the cash you pay your ex :oops:
So you are talking White Metal here , here is a bit from the wiki
The white metals are any of several light-colored alloys used as a base for plated silverware, ornaments or novelties, as well as any of several lead-base or tin-base alloys used for things like bearings, jewellery, miniature figures, fusible plugs, some medals and metal type.
Some of the metals that make up a white metal alloy are antimony, tin, lead, cadmium, bismuth, and zinc. Not all of these metals are found in all white metal alloys but are mixed to achieve a desired goal or need. As an example, a base metal for jewelry needs to be castable, polishable, have good flow characteristics, have the ability to cast fine detail without an excessive amount of porosity and cast at between 230 °C and 300 °C (450 °F and 575 °F).
OK so there are a few possibillities here but I will have to get back later as I am just going out :D
Could you supply a picture as i'm not sure what sort of setup you're thinking of, just out of curiosity (i can't remember an oil groove in the rear bearings for e.g.).. ???
There might be something in this:
Without spending a fortune on the engine, the DIY tuning options are limited
• First strip the engine down to make sure it's healthy.
• The standard engine is limited to maximum power at 4700 rpm, by its inlet breathing and cam duration.
• While increasing rpm, the most fundamental problems are, the crank strength and support, but should be fine up to 45 bhp, as long as it is balanced properly
• The standard crank will take 6000rpm, but is prone to blowing out the staked in oil blanking plugs (when rebuilding make sure to add a couple of spot welds).
• The crank can also whip, due to the lack of reinforcement in the crankcase and with standard sump
• But this can be reduced, by fitting a cast alloy Abarth sump, which also has the added benefit of holding more oil with greater cooling.
• The original Fiat 2-cylinder balancing is actually pretty good, although, a parallel twin can never be fully balanced.
To safely raise revs above 6,000 rpm, you require to consider the following
• If you want to rev above 6,000 rpm, you need a steel crank and a reinforced steel-encased main bearing (the standard crank flexes above 6,000 rpm and wears out the bearings and cracks the big cast iron main bearing carrier).
If you fit Ferrari Dino con rods, you get a beautiful rod and cheaper than many of the alternatives, and you will now have an engine which will rev to 6,500 rpm, all day long
• The single most important thing to do, is lighten the flywheel to the right degree, and along with balancing, this transforms the engine, allowing it to stay together really well.
Disassembly
This engine can be stripped down easily
• Parts that are oil stained can be cleaned with oven cleaner (leave to soak for 20 minutess, rinse with water, and dry thoroughly).
• The above technique will remove the black hardened sludge from engine components (unlike petrol or thinners).
• Corroded alloy can be cleaned with acid based alloy wheel cleaner.
• If regrinding the crank oversize bearings are available in 0.2 mm steps (speak to Middle Barton in U.K.).
Balancing
You can get all the components done professionally, or some parts can be balanced at home (as described below)
Connecting Rods
• Con rods have to be balanced end to end and overall.
• The end to end, involves holding the rod in a horizontal plane by passing a pivot through the big end or small end journal, and weighing the other end. The heavier rod then has to have metal removed from the spare weight cast as part of the rod at each end to match the lighter rod (this is done for both ends).
• Once the end to end balancing is done, the overall weights are matched by removing small amounts of metal from the shank of the heavier rod. This can be done at home using accurate cooking scales (down to 1 gram) or postal scales (make sure you place the end to be measured over the centre of the scales for accuracy).
Pistons and Rings
These are simply matched to the same weight by removing metal from the skirt of the heavier piston.
Crankshaft
• This presents a problem.
• The technique for balancing a parallel twin engine, is to attach a specific weight to the big end journals, and then spin the crank.
• This is to match the combined forces of the piston and rod on the crank.
• This weight figure is worked out by the manufacturer, and is the "factor of balance" (around 89%).
• However, when spinning the crank to balance it, you need this figure, to work out how much you add, to the big end journals, to counteract the balance weight on the crank.
• Unfortunately this figure is not readily available from Fiat, as they do not balance the crank in this fashion.
• However, most balancing firms should be able to do a reasonable dynamically balanced crank, along with the flywheel, clutch, oil filter/pulley, rods and pistons.
• You can knife-edge the crank if you have money to burn but its not really necessary on a non race engine.
Flywheel
• These come in two sizes.
• The earlier has a ring gear thickness of 12mm, and the later about 10mm.
• Some tuners do not recommend lightening, as weight helps reduce the crank vibration.
• If you wish to lighten, both types can be severely reduced in weight by removing the entire additional ring on the back and skimming the flywheel down to a minimum of about 7mm thick. (Leave the ring gear).
• This will reduce the weight by about 60% and greatly improves the pickup, and reduces the load on the gearbox, when changing down.
• The area where the clutch bolts on, needs more thickness for the dowel pins, so leave a thicker band in this area (10mm thick).
• Also do not remove too much near the centre, as the centre area dissipates heat from the clutch, or obviously where it bolts to the crank.
• Note that this machining will remove any effective balancing previously done on the flywheel at the factory.
• Don't go too mad lightening the flywheel, as it needs to keep a reasonable mass, in order to avoid the engine stalling, when the revs drop to tick-over.
• During balancing, the clutch diaphragm plate then needs fitting and clearly marked to align it in future.
Cylinders
Engine larger size increases torque, but doesn't have a great effect on engine power, so decide on your capacity increase (only 2 hp for every 50 cc increase, irrespective of any other modification)
• Increase 650cc to 700cc = gain of 2 hp
• Increase 650cc to 800cc = gain of 6 hp
• Increase 650cc to 850cc = gain of 8 hp
• 700cc is best for balancing, smoothness, taking higher revs, not producing any more heat, and holding together better (easy to do).
• Just rebore your 126 (650cc) barrels and fit larger pistons to get 700cc, but barrels that had been over-bored, get very thin at the bottom, and its not unheard of for them to crack at the bottom, and for bits to fall into the crank case (the proper 695/700/750 kits come with replacement barrels with the correct thickness at the bottom for good reason, but the crank case needs to be bored out to accommodate these).
• You can build up to 850cc (with VW barrels and pistons), and it works reliably, but produces lots of heat and doesn't balance well (so only if revs kept below 6,500 rpm, and a remote oil cooler is added).
• However, remaining at 650 cc (126 engine) is a good, reliable compromise.
Reassembly
A couple of points worth mentioning (as they are omitted in the Haynes manual)
• Firstly clean all the screw threads with cellulose thinners and let them dry.
• Loctite everything on re-assembly, in particular the big end nuts, as these have no lock washers.
• Make sure you re-torque the head nuts, after the engine has run for a while, as these come very loose when the head and base gaskets compress (always use new gaskets).
• The engine has quite high crankcase pressures as both pistons descend at the same time, pressurising the crankcase.
• This pressure should vent through a one way valve attached to the oil filler, to an oil breather pipe.
• Any restriction in this outlet, causes the oil to be forced out of the engine, past any slightly weak joint.
OK , back on the case. My first real classic car was a 1937 Talbot 10. The engine was a typical early 1930's design where the big ends & main bearings consisted of pure white bearing metal that was poured in molten form into the con rods , bearing caps & the crankcase . The crankcase then had to be line bored for the mains & the big ends bored to suit the crank shaft. Quite a performance with that type of engine and there are still companies around that do this type of work. As the 126 shell type main bearings come in their own removable cast iron housing I think that it would be possible to have a "custom" bearing made. It should be a relatively simple casting & lathe job. Also the bearing alloy mix/composition can be varied to suit different conditions/loads etc so you may be able to choose the type that best suits your engine [-/
Hi guys thanks for the input,
Rusty we both no there's more than just ali in the bearing but i will not be scrapping bearings like the good old days and wow input overload with that Darrell, Now I know what Jonny 5 felt like :P :P
Still had no luck in finding something suitable but may switch to half shells like an run off the mill type engine would have rather than a bush type that is fitted as present. I'll keep you posted but it's just too dam cold to go in the garage right now :oops:
You could go for shells but then you would also have to redesign the bearing housing. Another option could be to see if you could find a suitable camshaft bush that will fit the rear bearing housing.
With each standard main bearing costing silly prices in the UK because it comes complete with the cast iron housing it seemed to me that having one made to your specifications might be the way to go . We ain't talking about bearing scraping here & there are many specialists if you google it. If you get desperate I have got a small ingot of white metal in my garage [-/
Rusty you wouldn't have an ingot of gold in your garage going spare too :oops:
Been looking at cam bearings as you mention it, still trying to find something our size
I've heard of rocker shaft needle bearings for the rockers but not cam bearings....interesting.. :P
Smallcox, if you can find a correct OD size roller bearing, you can turn down the cam on its bearing mounts to suit the ID of the bearing. A mate has just done this on his V8 and picked up 15rwhp from this mod alone. Just a thought............
I like these thought [-/
Yeah, I thought it was a good idea too. I came up with the idea ages ago, and always wanted to do this to my windsor, but on my mentioning it, said mate went ahead and done it :o, He's now going overboard and planning to do the same with the crank. BUT I have my reservations on this. If you turn down the crank you could weaken it too much, and if you open up the block you could sacrifice main web strength (at least in a windsor V8). I'll wait n see what happens. If it works the benefits would be two fold, the roller bearing and the reduced diameter of the crank journal would allow very easy revving.
A thing to note for anyone trying this is oil pressure. We drilled a slot in the bearing case and lined it up with the oil feed hole in the block. It runs a high pressure oil pump and we found that the oil pressure galled up the rollers a bit. We put restrictors in the oil feeds and that solved the prob [-/
I dunno that oil pressure would be an issue as the 126 takes it's oil from the pump and pushes it through the camshaft to the rear of the engine, and then pumps it through the crank.
My dad tells me some cars have a hole drilled through the conrod up to the pin and there they have a hole placed to as to squirt oil up into the piston skirt....note to self must pull apart engine for 500 and do some tinkering along those lines.
The oil goes through a gallery I think up to the head and that oil that goes up the the head then comes down the pushrod tubes to lube the camshaft, might be holes in the cam but can't be rocket science to restrict these a bit to up the pressure....unless as normal I have that wrong. But have to confess to not paying too much attention to cams as my last engine issue was main bearing related.
As I see it that could be the part that buggers us up there as the camshaft is hollow :-X grinding it down might make it too thin but I have a brand new performance cam I can go measure.
I wish there was a tame bearing place round here to get some info out of. Our local bearing place just cant seem to get rid of customers fast enough.
SHHHHH! Don't mention the roller bearing on crank thing. Smallcox is obsessed with white metal, You'll get him all hot and bothered :P :P :P
I remember the 1980's GSX11's with their roller bearing cranks, they were awsomely indestrucatable engines ;D
pete have you not fitted needle roller bearings on your bis and they work fine?
just a thought but why not make them out of lignum vitae........?
Wo Boy , you are going to confuse the "public" with that one . As it happens I have got a couple of chunks of that but don't tell Smallcox !
Also got a small ingot of wood's metal which is quite useful & interesting :oops:
Pete have you not fitted needle roller bearings on your bis and they work fine?
I did try the needle roller bearing at the rear of the engine, had the bearing cap machined out to fit and left a 1.5mm shoulder on the outside of the carrier so the bearing wouldn't work loose to the rear oil seal, the bearing had a centre hole in the outer casing which was pressed in with bearing seal and aligned with the oil channel in the block, It worked well for 200 an odd miles then oil started to pour out of the rear seal, when i took it apart the bearing outer case had worked loose in the bearing cap, and had worked through the shoulder then pushed the rear oil seal out, so not very successful :( Don't know if it was something I did wrong :undecided2: but it nacked the crank so reverted back to the standard bearings and a spare crank I had [-/
Darrell, Who do you think planted the Seed, Sorry Steve :wink2:
Wasn't me :oops:
I only planted Radishes, Pumpkin, Beans, Peas, Letteuce, Cabbage, Tomatoes, Sugar beet, Peppers and Aubergines this year :oops:
Great one Darrell, if you send me some Radishes they may just work as bearing and the Letteuces will give it that crisp response it needs 8)
Ref Darrell post of 30 Nov '10.
As a newbe on this forum I am very pleased to find your list of "what to do" to strengthen the engines! Very helpful! Thanks!
We have had an "A" reg 126 from new but the gov'nr won't let me use it for "AutoSolos" (driving around a tarmac course set out with cones.) So negotiating for a pre-1981 126 at present with a plan to use a spare Shorrock Blower to improve the power output. Got to show those Spridgets how it can be done without conforming!
Engine strengthening will be a very good idea!
Thanks again
Andy
