Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: 1973/126 on November 17, 2010, 09:01:37 PM
So here is the thing. I have got a brand new distributor which looks like a 126 one, but the teeth on it are pointing the other direction. I hope you get what I mean. I`m not sure what it`s out off, but I`m assuming a Panda 30, or maybe an 850?
It`s a Marelli one. The numbers on it are B312A - 202 R1 1K. I couldn`t find any info on the net, so if anyone could help I would appreciate it.
I`ll try to put a picture on tomorrow.
If it is like the 126 then you can eliminate all cars that have a vacuum advance [-/
Rusty here are some pics for you, just to keep you busy ;)
Just a Guess but i would go with Panda 30 or Cinquecento 700 because the engine rotates anti-clockwise.
You should be able to swop the gears over ;)
Thanks guys. So most likely a Panda 30. I only wanted to know, as wanted to put it on eBay, but I think I might as well keep it.
