Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: massa on November 14, 2010, 06:31:58 PM
someone must no are the king pins fitted to 126 bis the same through out the say 500 models and 126 models some say yay some say nay i would of thought yes but lot of time may be wasted trying thanks lads dave
Bis and AC are the same.
thanks so i take all 126 are the same and 500 are different thanks mate
Mmmmmm I would say they are the same but only know 126, not 500s.
thanks again one stub axle to sort will make sure i ask for 126 bis king pin kit then mot time run a rx7 for summer had bis a while so keen to get on the road big difference to rx but ave always loved little fiats thanks for help
500 takes a smaller bearing thus the shaft is thinner.
I have a 500 and thought I could use some 126 king pin/knuckles/suspension bits on the front of it however the 500 bearings/drum wont go over the shaft hence the 500 is now on 500 rims at the back and 126 rims at the front :oops: only a temporary measure though [-/
Darrell is mixing up his front wheel bearings with king pins :oops:
Any of the kits will do [-/
Isn't everyone just getting the re-conditioned ones on the net now as they are cheap?
I renewed mine using a repair kit... though the front left is a re-conditioned one but i could've renewed 3 for that price!
my thoughts one kit for 40 quid does 2 stub axles good value me thinks thanks lads
Putting the new kit in I found to be a bit of a bother :oops:
It's difficult if it's rotted together (i had to hammer it for ages >:(). You also need that tool (broach?) to refine the inner surface of the kingpin sleeve...
