Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: bath126p on November 10, 2010, 12:16:29 PM
Title: A/C exhaust recomendations
Post by: bath126p on November 10, 2010, 12:16:29 PM
Hi guys
Snapped another A/C exhaust. The gf drove it with a broken bracket so that's why it went.
Going to have to buy a new one now, so wondered where people tend to source theirs. Would an aftermarket performance one, such as the one from 126Fan, be stronger?
Title: Re: A/C exhaust recomendations
Post by: dajwid on November 10, 2010, 04:22:17 PM
Standard ones work great, (just don't drive with a broken bracket) ;D
Mine have always lasted very well and are really cheap to replace.
Post by: bath126p on November 10, 2010, 05:06:50 PM
You are correct I know! No problems normally, but she's covering mega miles in it and something was bound to break.My fault really as I forgot to put the ratchet back in her toolkit.... whoops :oops:
I just wondered whether a performance one was worth the expense?
Where can you buy standard exhausts now? I feel a Ryanair cheapo trip to Poland coming on...
Post by: dajwid on November 10, 2010, 05:19:26 PM
TONS on Ebay.
Post by: Rusty's Uncle on November 10, 2010, 06:40:36 PM
My fault really as I forgot to put the ratchet back in her toolkit  :oops:
That could be the quote of the year but anyway how can you keep busting exhausts  ???
If they are fitted properly then you should be OK for 3 or 4 years regardless of mileage. OK the bracket broke but if you fit the exhaust under stress then it will fail. You should loosen the exhaust elbows at the head to get the right alignment before you lock everything down.  [-/
Post by: Darrell on November 13, 2010, 12:16:06 AM
My aircooled standard exhaust ran for a while, I got bored of it and decided to modify it....and that was the end of that....don't modify it!
So purchased an aftermarket sport exhaust which has stayed in-tact for two years or so with regulars use. It's black and has a single tailpipe.
I was a little peeved a little while after buying it as it said 'Abarth' which it is not.
Abarth started his carreer in bikes and exhausts and the company now making the abarth pipe for the 500 aircooled is IMSAF in Bologne. So if the best is required then I guess that is it however you would need to change the thermostat housing to the 500 housing which would add cost but shouldnt be too much of a bother.
In my experience if there is no stress on the downpipes and everything is tight it's all good and should be long lasting, but as with my experience I had a bolt come loose on the exhaust elbow which knackered the thread. I think the bolt came loose because of high revs :oops: as I'm not convinced my engine is 100% dynamically balanced.
Post by: Darrell on November 28, 2010, 12:00:46 AM
http://www.capassoricambi.it/public/shop/product.php?id_product=721
