Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: ciaoflyer on October 02, 2010, 04:12:43 PM
Right I have tightened my front hub nuts to 5ftlbs then backed them off by 30o as the manual states. Then staked them, however i can actually move the nuts slightly with my fingers, is this correct? After all I don't want them coming undone but I assume the stake will hold them!
Thought you had risked the jewels at Betfred for a minute there ::)
I Know what you mean about that movement once you back the nut off but I think that you have to be a little more brutal on the staking so the nut does not move. It is not a design that I like but we are stuck with it :oops:
Fiat wanted you to fit a new nut every time you adjusted or undid the hub nut but if you are careful you can normally recycle them a few times [-/
It's my preference to have them just a fraction tighter than that.
Is it worth tightening them a little more or just staking them where they are?
if you have gone by the book then that will be fine if you tighten too much you end up prematurely wearing out the bearings. i used to drive a golf mk1 and the rule to tightening was to back off and be able to lift the wheel using a small screwdriver between the nut and bearing which is far from being a technical operation.
For a minute there I thought you lot were talking about an operation Mussolini with hair (mother in law) would like to perform on my person...
I'm with bis13, too tight and the bearing will be knackered, I know, I've had one go :oops:
I have always adjusted wheel bearings to the point where there in no play and locked or staked them there. I've done this on road, race and rally cars and never had a problem. I over tighten the nut by about an eighth of a turn then back it off and then tighten it slowly , checking as I go until there is no play and that is it. I always do this with a road wheel on the car to give more leverage and a better idea of when the play has dissappeared.
I thought with the 126 there needed to be a small amount of play?
Taper roller bearings are extremely high precision items and they will run very happily with the minimum of clearance / play but as has been pointed out here , even a little over tightening will quickly ruin the bearing hence the manuals tend to air on the side of caution . If you over tighten the bearing you will feel a resistence / "grumbling" when you spin the hub .
WAhoooo! Went straight through thr MOT so back on road! I assume that means everything is fitted ok? The MOT man said there was a slight bit of play in the bearings but he said that this was correct for this type and it was well within MOT 'excessive play' regs!
:D :D
