Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: mark_stoke on September 25, 2010, 12:31:09 PM
Title: Brake Pipe Threads.
Post by: mark_stoke on September 25, 2010, 12:31:09 PM
I recently installed all four brake cylinders on my Bis, all the brake pipes were good apart from I broke the one pipe section that screws in between the near side rear cylinder & flexi-hose (the section about 10" long). I took this broken pipe to a garage & they knocked me up a replacement.
The thread on this new pipe will not screw into the cylinder, the thread is metric, the cylinder is new & with a clean thread, I've also tried it in one of the old cylinders that I took off & it will not screw into that either. My Bis is 1991 & my new cylinders are correct for this car & I am told that the threads should be metric.
Can someone please tell me what might be the problem?
Title: Re: Brake Pipe Threads.
Post by: ChrisRLewis on September 25, 2010, 06:00:19 PM
I think Fiat use an unusual 10mmx1.25 thread pitch on their brake unions. The normal metric size unions are 10mmx1.0 pitch. Perhaps someone else could confirm this?
Post by: Rusty's Uncle on September 25, 2010, 06:17:15 PM
Yes Chris is correct & the old type Fiat unions are quite hard to get hold of so I tend to refurbish good used old ones but I did manage to pick up a few new ones last year if you get stuck  [-/
Post by: mark_stoke on September 25, 2010, 08:23:53 PM
Thanks for your reply, I left my original part at the garage so if any one has two thread bits spare it would be greatly appreciated.
Post by: Rusty's Uncle on September 26, 2010, 12:02:26 PM
Have you got the correct length for that brake pipe  ???
Post by: mark_stoke on September 26, 2010, 03:48:40 PM
It measures 12" long.
Post by: Rusty's Uncle on September 26, 2010, 06:38:12 PM
Hi Mark , sorted out a couple of good used unions , a suitable bit of copper brake pipe & I have a professional pipe flaring tool kit so PM me your details & I reckon we can get you back on the road  [-/
