Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Rusty's Uncle on September 22, 2010, 05:52:46 PM
Fitted my new handbrake cable today after being mis-sold a 126 one last year and limping along with a handbrake that hardly worked . It is a pig of a job having to remove half the interior then working inside & underneath the car. Then when you have got it fitted the hardest bit is replacing the split rubber grommets that protect the cables & pipes that run out of the back of the tunnel through the rear bulkhead. Anyway got it sorted then found that the handbrake was almost worst than before. Bearing in mind that the car has now done over 100,000 miles & some parts are original. I have new brake cylinders & shoes now the cable. So I think that the linkage inside the brake drum must wear as there is no lip on the brake drum surface . Got the handbrake to just bight now so hopeful about MOT [-/
