Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Rusty's Uncle on August 27, 2010, 02:14:28 PM
Title: Fuel lines & Filter
Post by: Rusty's Uncle on August 27, 2010, 02:14:28 PM
After my massive overheating episode when my cooling fan blew one of the scariest things was opening the engine cover & seing the petrol vapourising in the plastic fuel filter which had blown up to more of a ball shape and the walls felt more like a plastic bag. I think that it was on the brink & if it had let go then it would have been a rather different story  :oops:
So I had already picked up one of the aluminium filters that one of you guys recommended a while back and have bought some 6mm bore stainless braided hose complete with rubber end fittings & stainless clips. Then spent about an hour trying to get one rubber end fitting over the frayed ends of the braided hose  >:(
Stepped back & had a rethink , nothing on Google then used a little insulation tape around the end of the hose with a slight overlap at the end so the steel strands were tied in but not so much that the tape might interfere with the pipe bore. End finishers then popped on in seconds  [-/  Sorted
Title: Re: Fuel lines & Filter
Post by: dajwid on August 27, 2010, 07:02:00 PM
Bits of braid still stick in your fingers ::) Been there done that looks great though and much stronger.
Post by: Rusty's Uncle on August 27, 2010, 07:50:40 PM
Yes prickly little bits on those ends. I have not tried cutting the hose yet as I want to get the runs right. Question is why are the filters always fitted between the fuel pump & carb rather than down line from the fuel pump  ???
Post by: Eklipze3k on August 27, 2010, 08:26:07 PM
I think you should change your screenname to McGyver  ;D
Post by: Allan on August 27, 2010, 09:23:59 PM
It's the difference between sucking and blowing Uncle Rusty.
Post by: Darrell on August 27, 2010, 10:37:34 PM
Pumps create more pressure downstream, than negative (suction) pressure thus in the discharge side blockages will not hamper fuel flow as much.
On the suction side it'll work, but any slight air leak will make the pump loose prime. It's easier to spot leaks on the downstream side too :P
That engine must have been steaming!!! My overheating eposide must have been nowhere near as hot as yours got :oops:
Hate it when those frayed bits go under finger nail >:(
Post by: bis13 on August 28, 2010, 09:44:34 AM
i would suggest that rusty gets an extinguisher and some fire proof pants! as for the bits of metal in the fingers thats part of the fun of diy braided hoses! just hope that they are not the cheap type and dont end up turning green!
Post by: Rusty's Uncle on August 28, 2010, 01:24:24 PM
My Wife seems to keep on trying to burn my pants for some reason but they seem indestructable  :oops:
The massive overheating was when I tried to drive 5 miles home without a cooling fan.
So went for the filter on the "blow" side secured to one of the screws on the fan housing using a large P Clip. The stainless braided hose cuts very easily with a junior hacksaw. As the hose is fairly robust it does not need any additional support if you get the lenghts right. Conected pump to filter , filter to carb first & the two part filter was leaking petrol. So unscrewed one end , turned the handed rubber seal around & it seems OK but keeping it under observation. I guess that the plastic pipe on the inlet side of the pump had been shortened over the years as the solid feed pipe was not in its location tabs , it had a jubilee clip at one end & a simple cable tie at the other  ::)
Anyway now sorted  [-/
Post by: smallcox on August 28, 2010, 04:33:52 PM
Nice job Rusty,
This something I must do, as I to run a plastic filter only waiting for it to explode someday [-/
Hope the little pricks in your fingers have healed but I guess you’ve been there before- lol :P
Post by: Rusty's Uncle on August 28, 2010, 05:00:06 PM
 ;D Oh my word , here we go then , no stopping you now smallcox  [-/
Don't forget that if you can't get online check that the computer is turned on & that wire thing is plugged into the wall socket  </4
So apart from running a plastic filter you are also running a standard fan on an engine that revs well over 6,000 rpm , dangerous territory  :oops:
Post by: smallcox on August 29, 2010, 10:55:49 AM
Yes the computer wire thing is in the back and it only take forever to boot up, so I still hate computers.
Also the standard metal drum fan still sitting complete with all it's vanes, unlike someone I know :P.
 Winter project is planned for the little 126 as this year I see just over 6500rpm I suspect well over 7000rpm is expected and will be ready for next year, fingers crossed, so a fan upgrade with a larger pulley on the alternater to slow things down (just like my computer,lol) is expected.
Post by: Darrell on August 29, 2010, 11:25:24 AM
Steel crank?
Lightened flywheel?
7000 rpm is going to make that beasty quickest in class at Retro Rides  :D :D :D
I'm regretting not going on the track, remind me next year what I have just said :oops:
Post by: smallcox on August 29, 2010, 11:35:41 AM
Darrel,
    it's like this , I will drag you on the track next year screaming and kicking */-
Smallcox
Ps you maybe right about that steel crank, but don't tell my wife
Post by: Darrell on August 29, 2010, 11:39:32 AM
I'm trying to funnel some money out of the budget myself for the same, and pistons liners and rods and flywheel...
silly fool here went and blew it with buying a 500 :oops:
Post by: Rusty's Uncle on August 29, 2010, 11:53:53 AM
I reckon that Mrs smallcox & Mrs Darrell might ban you two from Retro Rides  :oops:
Getting back to practical things those plastic filters can be very useful as you can see what is being pumped into the carb. One of the good things about my car is that it has been in constant use since 1972 & not been laid up. So the tank is nice & clean going by the filter bowl & it did help me spot some dodgey petrol I picked up that had some water contamination. I have had problems in the past with 126s that have been laid up for long periods.
Post by: smallcox on August 29, 2010, 12:07:39 PM
I agree with you Rusty, cars that lay about will contaminate the tank and block small jets in the carb when flushed through with the petrol, a fuel filter is defiantly a must, can save hours of future fault find and breakdowns.
 The only problem I have is I run my fuel pressure at present up to 22 psi and that not good on that plastic filter so an Ali one must be on the Christmas list [-/
Smallcox
Post by: Darrell on August 29, 2010, 08:50:57 PM
I agree with you guys.
The only good thing about 'low mileage mint 126's' are pretty bodywork. I wouldn't trust one on a trip longer than 50 miles without full AA/RAC membership!
126's don't like standing and it takes a while of regular use to get them reliable.
There is some stuff they advertise in Frost that is like a coating for the inside of tanks. It's white, I heard it is used in aircraft fuels tanks. I was thinking of trying it on my XS11 tank as that has a few visible surface rust spots on it.
Anyone else tried it?
Personally I think most of the dirt comes from the underground fuel tanks at services. I've noticed the filter stays clean-ish for ages, then suddenly fills with dirt and I've done over 25000 miles in mine now in 2 years.
I run a plastic filter as I'm regulated to 3psi. Thinking the glass is the way to go too :oops:
Post by: bis13 on August 30, 2010, 08:21:21 PM
you lot are getting way to posh send me your old plastic filters and i can hoard them for that "will come in handy one day" feeling.
