Fiat 126 Chat => Fiat 126 Chat => Topic started by: ciaoflyer on August 26, 2010, 06:51:46 PM
Do you think these wheels will look good on a 126?
13", 98 PDC, 2 Offset
Yes, they look great on a 126.
These ones? Im also considering them if they are
Just bought some! [-/
Hope they look ok! I suppose anything is better than the Polski branded hub caps!
Just be aware that the little hubcaps are not that well attached and seem to enjoy falling off.
Mine were missing :D
Told you
be carefull as these wheels are made from carbon and that with age they get very brittle so if you have a wheel to kerb experience it could bugger a wheel easily, Jorge used to have these on his bis and refurbed look really good.
I have a very strange issue with them. I fitted the rear ones and all was well, look good even if they do exagerate the camber!!!
However the front drivers side wheel (its LHD) is set further forward than the other side! Its only slight but means the wheel rubs the front. I have no idea why its like this. Everything is in good condition (its not rusted out) and its not had an accident. Is this normal??
It looks like a drag car now with fat rear wheels and the narrow fronts!!!
what size tyres are on these rims?
Need to double check but im sure they were both the same
155 65 R13 , all four of them! >:(
I ran that size on a lowered Aircooled 126 . I cant remember the make of tyres but one make cleared the front OK but the other did not so went on the rear [-/
I had the same problems with mine (not X1/9 alloys). All four alloys are identical but my rear tyres are thicker than the front ones. I do not remember the specification of the tyres. I will have a look tomorrow.
I have a similar problem on my 500 where one side was rubbing on the front. I too have 13" 5J wheels. On the rear I have Pirelli 155/65 R13 tyres and i did have them on the front too, but i could only turn about 1/2 lock, so not ideal.
I have since been fitting Michelin 145/60 R13s to the front and keeping the 155/65s on the rear. It works a treat.
The tooling alignment seems to be dodgy on the 126, mines an 80's model and i noticed where the gear linkage goes through the rear floor the tooling hole were 5mm out off alignment(offcentre)? This men't the nylon plug would not fit correctly and had to modified. Then moving around the car YES the front was mis-a-lined on assembly. I thought it was just mine but now can see this is not the case. the front wheel are slightly offset on the front and one is further forward than the other so this is normal. I did adjust and re-aline mine but took forever :oops:
It's a cheap production car 8)
Having owned many Lancia's (They used to just substitute parts when they ran out during production so a Delta would end up with Thema parts on it!!) and knowing how accurate Fiat group build cars i thought it would be a standard 'feature'!
I will try some lower profile tyres on the front, i suppose it gives me chance to have the front wheels refurbed whilst they are not fitted, then i can swap and get the other two done!
it could be that the wheel geometry is slightly different on the front i used to own a golf mk1 cabriolet and these have a similar thing in that the front wheels are not in perfect alignment for a reason i do not understand.
Front:155/65R13 73T
Rear: 165/55R13 70H
What does the last three bits mean?
speed ratings i think
The number is a size code and the letter is the speed rating.
I always get a bit anxious when it comes to MoT time as the tire thickness of my 126 Bis is different in the front and rear. Are there cars were the standard (non-modified) front tire is different from the rear tire? Can the MoT people actually insist on putting back the original spec. wheels and tires? It went through MoT before though with these alloys and tires but I need to be armed with an answer, just in case.
Yes the letter at the end is the speed rating so H I think is up to 130 mph Perhaps best to go for V which is over 130 Just in case you find a long downhill section on the road
The tyres just have to be the same on its common axle, so both rears the same and both front the same.
