Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Worm on August 17, 2010, 07:28:28 PM
Title: Valve Numbers/Order
Post by: Worm on August 17, 2010, 07:28:28 PM
Been reading the Haynes so i can check my valve clearances on my 1983 Aircooled 126, but the haynes does not identify which 1,2,3,4 are when looking at the pic the are no numbers, so when No.4 is fully open i should be checking the clearance of no.1, but which ones are 4 and 1 etc? Thanks for any help :-X
Title: Re: Valve Numbers/Order
Post by: Rusty's Uncle on August 17, 2010, 07:41:43 PM
1 is the one nearest to you but it does not matter as you can count it both ways on the 2 cylinder engine . All you have to do is think 5 so when 1 is down you set 4 , 3 is down set 2 & so on  [-/
Post by: Worm on August 18, 2010, 08:37:01 AM
Thats great. Thank you [-/
Post by: Worm on August 21, 2010, 01:40:11 PM
Bit of a thicky question, but i would like to clarify it "When 1 is down (does this mean compressed spring on 1?) as the haynes say Valve fully open, i am right that the valve is fully open when the spring on that valve is in the compressed state?
Post by: bis13 on August 21, 2010, 08:09:08 PM
in a word yes.
Post by: Worm on August 21, 2010, 09:48:50 PM
Cheers Bis13 [-/ Good to know i will have another go :oops:
