GSXR I reckon you are just attention seeking ;) It was a small fire & it was only petrol :oops:
I know you guys rip the sleeves off your shirts so they do do not get in the way when you are putting out fires [-/
Now if you had wrestled a croc to extract a suitable size tooth to jam in the hole that would have been a story !
</4 </4 </4 </4 </4 </4 </4 </4 </4 </4 </4 </4 </4 </4 </4 </4
On a more serious note that is a well documented problem with the 28 IMB carb & I am running one on my 500. I was thinking of fitting the fuel return line but I think that you have just convinced me to drill out & tap the hole & block it with a screw. The 500 cars with the 26 IMB did not have a fuel return line [-/
