Fiat 126 Chat => Your Restorations => Topic started by: Darrell on July 27, 2010, 10:25:02 AM
Title: New baby - big job ....
Post by: Darrell on July 27, 2010, 10:25:02 AM
Was hoping to get it onto wheels, so my bike trailer isn't tie-up for months but wasn't to be.
Found some old 126 knuckles to put some front wheels on but the springs are missing for the rears.
Good bits are new panels fitted to floor, inner sills inner front wings and inner front panel.
Bad bits are doors and panels missing but friday i go collect all panels required for the job.
Bits still needed - 500 engine mount, 500 gear box mount, 500 rear seats as 126 ones dont fit, knuckles for the front as 126 hubs are bigger, starter bit to bolt onto gearbox(have two 126 starters so replace front bit) quarter light windows, voltage regulator, rear springs (think I have made a plan) , no doubt all available through the trade but any offers welcome ;)
Title: Re: New baby - big job ....
Post by: rmbruton on July 27, 2010, 11:05:57 AM
looks like alot of fun. good luck
Post by: 1973/126 on July 27, 2010, 11:44:35 AM
 Looks like a lot of work :)
 Darrell I think I have got the engine mount as well. If you are looking for the original 500 type. It is still mounted on the back panel. I have a look, as I think I might have a starter too.
Post by: GTMaster on July 29, 2010, 08:16:28 PM
Don't forget to have fun while you're at it  [-/
Post by: Darrell on July 29, 2010, 09:53:21 PM
New panels collected today 4 new inner wings, 4 new outer wings, front panel and doors [-/
Knackered now with all that excitement :oops:
Post by: michaelodonnell500 on July 29, 2010, 10:02:03 PM
you got any pics of the doors (once you've had some rest!!) might have to get a set at some poin, keen to see how they fit
Post by: Darrell on July 29, 2010, 11:24:10 PM
Typically I couldnt help myself but put a bolt in the top hinge and bottom hinge to see what they look like. They look very good! They're heavy too! Heavier than I expected and seem really solid, wish my 126 doors were like them.
The sills look like they are in the wrong place and really need to sort out a better way to support the car this weekend before trying to fix any of the panels to the car, but Rome wasn't built in a day, just made me smile to see the cars 'face' for the first time :)
Pics of the trial fitting [-/
Post by: Pete126 on July 30, 2010, 07:58:35 PM
That looks good Darrell :P Will it be ready for Retro Rides :D
Post by: Darrell on July 30, 2010, 09:28:53 PM
Yeah mot next friday...NOT :P
The inner-inner wheel areches are giving me trouble, although they have been replaced, they seem like they are almost from another vehicle! :( Not sure what the solution will be but it looks like the angle grinder will be hard at work again.
Progress this evening, left door fitted and squared-up, all four wheel on so it's off the bike trailer.
Left rear wing cut-off ready for new one, Inner rear left wing tacked-on. Tryin to tack the inner front wing on and it's not playing ball at all!
Sills seem like they from another car too, well, the ones that came with the car so ordered new ones to replace them, should be with me for next weekend.
I figure if I can get a fairly sturdy frame (sills inner wings etc) I can turn it on it's side and start pulling underseal off.
Although it has new floor panels, it's not a pretty sight :oops:
Post by: Darrell on August 16, 2010, 09:21:55 AM
A weekend of destroying my hearing, skin off nuckles etc has resulted in a very sturdy shell now.
Welded-up the inner bits to ensure she's solid and fitted the pannels. Primer on the door front way to check nothing is rubbing. Door etc needed fettling, just got to finnish-off the front now which I imagine to be another good weekend's work.
Think I'm sticking to 126 hubs on the front, will get adaptors for 500 rims with the intention of going disc brake but for now can use 126 drums on the front.
Post by: Darrell on August 16, 2010, 11:41:39 AM
I've promised Rusty to write down all the bits I still need.
Front headlamps complete
Front indicators complete
Corner lamps
Quarter light windows complete
Grill bit and wiskers
Adaptor plates 126 - 500 wheels
Wiring loom - the one in the car has been hacked to pieces
Front bumper bolts and spacers
dizzy cap, rotor and leads
Exhaust
1 x exhaust elbow
carpet
rear seats
front boot (bonnet seal)
front boot mat
master cylinder reservoir
master cylinder reservoir rubber mount
spare wheel
tyres x 5 (135-12)
rear suspension bushes x 4
front suspension spacers
brake pipes - all
accelorator cable - original one was cut! :(
big pipe to engine
small pipes from engine (heater)
steel bit of the ducting (heater)
hose up to dash
Rear lamps complete - ones on the car are cracked and bits missing
Rear soundproofing
Gearshift seal
Clutch cable
Wipers
shocks - miss match with car
Wishlist:
126 engine
126 box
disc brake conversion
126 gearshift complete (500 one does not have the antirattle spring)
That is all I can think of for now, More will become apparent as I go I'm sure.
Thanks to Lad for the rear panel and mount, gearbox mount and front suspension bits, a huge help!
Post by: kitten75 on August 16, 2010, 12:27:58 PM
It's great seeing the transformation taking place!  I ordered a new engine for my 126 on Friday so my old engine (without valves and springs and god knows what else missing/broken!) is on offer if that would be of any help?  Obviously long way to courier it...but offer's there.
mhairi
Post by: Darrell on August 16, 2010, 03:47:23 PM
Hi Mhari no just hang-on to the engine you have for a bit as you never know what you may need to complete yours.
Perhaps we can talk once it's up and running, I have a feeling I could use the crank and flywheel  [-/
I'm crazy enough to drive a 126 to Scotland too... :o
Arrival of a new toy today to complete the restoration  [-/ [-/
Pops (my dad) has advised me throughout the build and being he is a panel beater having worked for the likes or Rolls Royce I take his works as being from a guru.
So no more tacks...spots instead!! :oops:
Post by: RSPSTEVE on August 16, 2010, 04:17:23 PM
Nice one Darrell
Looking really good , good skills and the spot welder will be a god send ..lol
Steve
Post by: stuey on August 16, 2010, 04:47:46 PM
some great work here darrell I am watching with interest- wish I had a spot welder when doing my front end on alan..
keep it up!
wiring loom link if your pockets are deep- http://www.autosparks.co.uk/product_info.php?products_id=2556
Post by: Rusty's Uncle on August 16, 2010, 05:07:16 PM
 :D Very impressive Darrell especially as the car appears to have been far less complete than the seller said & you had the odd dodgey panel thrown in for good measure. I did see some steel wheel adaptor plates on one of the web sites, do not go for the ally ones. Some of those bits on your list are as cheap as chips to get new parts , some will take a little more luck/cash  ;D
Keep up the good work  [-/
Post by: Darrell on August 16, 2010, 06:32:10 PM
Thanks Stuey and Rusty, yes i guess complete is as complete gets  :oops:
The quarter light windows are going to be the fly in my ear i think, and as you say the rest is cheap as but all add-up too damn quickly!!
So far about £900 spent and guessing £600 to finnish to a complete car with and engine that runs, although, this all depends on how much fiddling with performance I end up doing as I'll be bleak with standard 499cc performance after the 126..
No doubt wifey will be watching the budget very close  :oops: I'll sneak past her somehow, I have my methods...
Will post more pics after next weekend's battle with the metal, don't think the progress will be as visible as it'll be work underneath on rear spring seats :-X, just the left wing and front end to square-up and weld on.
Post by: 1973/126 on August 17, 2010, 09:13:51 AM
 Hey Darrell you are doing a great progress there, especially considering how the car looked before!
 Can`t believe someone would sell this as a complete project!
 I`ll keep my eyes open for these bits.
 Keep up the good work. [-/
 Lad.
Post by: Darrell on August 17, 2010, 03:25:36 PM
Thanks Lad,
I think any 'slightly rusty' 500 would have needed the same amount of work and bits in reality.
I've seen a few on e bay which look complete, but when it comes down to it, most of the panels could do with replacement hence there is method in my madness, someone else cut most of the old panels off for me ;)
Post by: Rusty's Uncle on August 21, 2010, 08:02:45 AM
Hi Darrell , I made a note of your shopping list and have some bits & many comments so best to have a chat sometime  [-/
Post by: Darrell on August 21, 2010, 09:41:43 PM
Bzzzz Bzzz Bzzzz.....grauraaaooooo.........bang bang bang......Bzzzzz Bzzzz
Post by: Darrell on August 30, 2010, 06:47:59 PM
No more pics this weekend, just more bang bang bang bzzzz and grinding noises.
Rear inner-inner wheel arches are rubbish, took a while to get the two sets of patches off them to see what's up with them...
A patch on top of a patch....and past welding makes my welding look like a pro! :oops:
Spot welder blew-up the 240-110 transformer spectacilarly! A nice greeny-brown smoke bellowed from it leaving my good lady cursing that I 'filled her house with smoke'
Post by: Darrell on September 03, 2010, 10:02:01 AM
I'm away on holiday this next week :) Reports to resume when I get back [-/
Post by: Darrell on December 17, 2010, 11:47:29 AM
As a help to my friends and family, a list of items on e bay has been supplied to them as I have now taken to blantently hinting.
Nobody made an effort for my 40th so with pig-headedness I shall ensure no-one forgets my 41st in January!! There's xmas too!
And never being one to call in on favours, they all better know they owe me!!!!
So with a bit of luck and generosity 'Bella' will be beautiful soon :)
Post by: Darrell on May 07, 2011, 09:30:13 PM
Loads of comitments toward the end of last year left Bella under the cover till last weekend.
Car situation changed drastically with the addition of a VW Passat, company car given back and 126 no longer being used as a daily driver.
Probably better for the 126 to become a proper toy :P
Completed welding-up inner left rear wheel arch, new spring cup and jack point welded-in, all work rust treated then undersealed.
Small camera has been broken and not willing to use SLR when sparks and hammers are about so description will have to do for now.
Work to continue next weekend on right inner wheel arch etc. Will update pics when done.
Jobs still to do is weld-up and check geometry of front-end.
Tidy up panels which have been replaced, prep and then off to the painters for some of that lovely fiat creamy white  ;)
Parts missing still, quarter windows complete, front brightwork, lights, adaptor plates to fit early 126/500 wheels to 126 hubs, tyres (the ones on the car are rubbish) and a spare wheel.
