Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: Jota69 on July 14, 2010, 11:20:38 PM
I'm in the process of rebuilding my 650cc engine and I'm looking to upgrade to 700cc. My question is, is it possible to bore the stock cilynders to 79.5 mm or will I need to get 79.5 mm cilynders?
You can use the 650 barrels but its a bit risky in my opinion. The barrels taper at the bottom and when over-bored they get very thin just below where they are inserted into the crank case. I have heard about several people who have had them fracture and chunks fall ino the crank causing a nasty mess!
On the other hand I know people who have been running them for years with no problem.
If you buy a good piston and barrel set it will have thicker walls at the bottom. The down side with this is that the crank case needs to be stripped and bored to accept the bigger barrels.
If it was me I would buy a barrel and piston kit from somebody like www.gozzoli.it or www.equipetorino.it
Nigel
Douw!!
hudsonhenry just posted another couple of 126 porn sites!!! [-/ [-/ [-/
Will my wife ever get her conservatory?!
with google translate toolbar as a must [-/
I found a machine shop that would bore your old cyclinders out and sleave them the size you require , but due to cost I found it best to order new cyclinders the correct size. As mentioned above, then you have to bore the engine block to accept these, because there about 1mm bigger [-/
