Fiat 126 Chat => Fiat 126 Chat => Topic started by: icbis on June 24, 2010, 04:43:15 PM
ok - the car i want to buy is spot-on; just one thing: it's a bis & it has 135/80/12 tyres! i measured the wheels: they are 13" across [external dimension] - is this something i should be concerned about? what problems could this cause? i really want this car - but the 12"-tyres are baffling me!
If you have measured the rim edge to edge in a straight line and its 13" there's no way the tyres are 12" they just won't fit.
I was just about post the same :) hi hi hi, How did you come to the conclusion tyres are 12"??? If anything like it is pressed on a tyre you just made a mistake measuring it :D
Even if they are 12" tyres the OD of the tyre they used on the 12" was the same as the 13".
The 13" tyres and rims are easily found. I have two in my shed, I'm sure there are other members with 13" kicking about :oops:
According to the owners manuals the a/c was fitted with a 135-12 (80 series) and the Bis with a 135/70-13. The height and circumference of both these sizes should be so similar as to not make any difference.
That is I should add until you start talking to Rusty's Uncle about disc brakes.
ok - thanks for that, guys; the tyres are stamped 135/80/r12 - but the rims i measured were definitely 13" across! should i still buy this car??!?
oh, btw: the tyres are all brand-new! :P
If the bodywork and engine is good then the rims are a small detail no?
It's your call really :oops:
I would guess that you are measuring the rims incorrectly, it's the inner rim of the wheel that should be measured, see pic.
There's no harm using 12" wheels, so if the car is good go for it, you can always revert back to the 13" wheels at a later date.
I might have some 13" steel rims from Cinquecento somewhere....
ok - thanks again! yes, it would appear that i measured from the very external edge of the visible wheel. it's an awesome car, otherwise; i'm just baffled as to why someone would put 12"-wheels on it! any ideas on that? wouldn't it drive better with 13"-wheels?
simple question look at the wheels are the holes in the wheels round or rectangular as the 13" are round and 12" rectangular (thats if they are fiat of course).
which holes - the hub-nut holes? they are definitely fiat wheels - they say 'fiat', on them! what will this answer to your question mean?
bis13 meant these hole if i am right :D
These pictures are 12"
yes, they look pretty-much the same as those - is that a problem? do we have a 13" photo to compare? thanks for all your input! 8)
if they are like that then they are twelves as the 13"s are ROUND which means not rectangular! ;) i hope this helps as it will mean they are the right tyres for the rims but not the car(bis) which isnt really an issue unless you are not happy with that. if thats the only problem area with the car then go for it!
yes, thanks for that; thankfully i know the difference between round, and rectangular : ] i'm just wondering why on earth anyone would put 12"-wheels on a bis? any suggestions?
There might be a MILLION reasons - all not important at all :D
In whole eastern Europe people used to have whatever they were able to hold of. It doesn't affect performance, can't do any harm to the car and if I would be you wouldn't be bothered at all.
My opinion - if the rest of the car is fine with you forget about these dman wheels mate [-/ and buy it.
Just to make you feel better and fully sure - below picture of standard 13" rimm.
ok - that's splendiferous news [-/ i guess i ought to be pleased that it actually has some wheels :)
So now - go for it tiger! No more mouning and post some pictures man.... 8)
who's/what's mouning? ;)
