Fiat 126 Chat => Fiat 126 Chat => Topic started by: Jan-in-UK on June 24, 2010, 12:24:04 PM
As per title - does anyone knows what is (even teoretical) process of getting it registered properly in the UK?
Should I be aware of any major issues?
The only way to find out is to have a word with the guys at your local MOT (vosa) testing station, There are so many new Laws they would be the only ones to advise you and stay on the right side of the Law.
Is the car registered in Poland as a 126 1.2MPI This may make a difference. If the MOT guys don't know they should be able to give you a telephone number to make the enquiry.
Car is still registered in Poland. But it is in my name so might be an idea to first MOT'd this monster, then go to DVLA and register it as 6500cc. When it is done and number plate given notify them of changes done?
I don't know yet - will have to make some researches. Thanks for a tip with MOT station, didn't think to go and ask.
By now picture of a monster's heart. Will make some movies in Windsor this weekend and put in on youtube for all here to see :) this is seriously quick machine now. Loads but loads modifications to whole car.
Hi Jan
As far as I know you need to register it as a standard car with a 650cc engine with the DVLA.
Once you have the documents back you will need to write to DVLA again with the new engine number and cc.
They will need varification from a UK garage that the engine that you say is fitted is indeed fitted. If you do not send this with your notification of change they will write back to you requesting it.
They should then send you a new registration document.
If you are very unlucky they may then ask you to take it along to a VOSA center to see if the modifications you have made require a BIVA test - if you have modified any part of the shell structure it will need a test otherwise its on the points system, see http://www.the-ace.org.uk for up to date info.
Im not sure what will happen if you just register it as a 1242 straight from the off it might save time, what does the Polish paperwork say?
going by the site you recomended it states that jans car would require to have a niva test and meet the new car regs! ouch.
Reatcher I would burn in hell then attempt such a thing :):):)
an apropriately shaped metal plate with 3 letters, 3 numbers, 1 letter, 2 numbers, 8 numbers...., those rectangly shaped things found on either end of another 126, and a left rear window (with a small stiker on it) swap will be my registration process should i have any difficulties.
We have different rego rules in Sydney - basically build to certain guidelines, get an engineer to approve it and your off.
But...........most people (including the constublary) havent seen or dont remember what a 126/Niki is anymore.
About two weeks ago i was cruising with a mate in his 850 coupe. We were pulled over for a "random breath test". After the test the copper asked to pop the bonnet, mate replied: you dont want to see anything under there, copper thought he was being smart and insisted. Mate opened the bonnet to reveal a fuel tank, radiator and other bits and pieces, much to the copper's amazement. Mate said: you want to have a look in the back, so he opened the hood to reveal a 2 litre, turbocharged, supercharged lancia motor. The copper stood there not knowing what to say. After a few minutes he asked: is this standard?, to which my mate replied Yes except for the wheels and a couple of other bits, and he let us on our merry way....
Only in Australia could you get away with that and I get a ticket for 120 on a back country road.
Its not quite new car regs but you need things like collapsable steering column and radiused edges.
It is possible to build a 500 or 126 with a FIRE engine within the 8 points system, I'm doing it at the moment, you just need to use an un-cut shell. You can bend and stretch the metal but as soon as you cut you have a problem. I had tubbed the rear arches on my shell but because of the clarification I got from ACE I have re fitted standard inner arches and rear quarters but, using an arch roller, stretched them out of the way (as much as was possible). I plan to put wider fiberglass arches over the to of the originals held on with rivinuts. I might not be able to run as low as I would ideally like but I will not need an IVA test.
The radiator will either be mounted in a 600 Abarth style fiberglass bumper or somewhere underneath or even behind the car so that the body does not need to be cut in any way. Building the cat this way also means that I can easily take out the water cooled engine and radiator and slot in an Hot air cooled twin without any major work.
The Australian build book system is what we should have here, although I heard recently that all imported manufactured after 1989 now have to be bog stock or they are not allowed in to Aus. Once in they can then be modified.
Nigel
Hi Nigel i have a question about the front end with regards to radiators as you might know the answer. If louvres are cut into the front panel would that constitute a modification of the monocoque? as the Ace site states that if it does not alter the strength of the original body then it should be okay? If not is it okay to cut louvres into the bonnet as that is not part of the structure? or am i getting it all wrong and just wishing it is so?
I have to move soon as i am relocating to the isle of wight so it looks like my pile of scrap yellow roadster dream is going to be binned and a more realistic conversion of my black car to be the future, i also have a similar view to the conversion/reversion of engines.
I am interested in any ideas you may have about radiator locations as it is something i must get around to make this easier.
Cheers Mick.
Mick
Great to hear from you, I hope the move goes well, we are on holiday on the Isle of White in August for a week, Ill keep my eye out for you 126
As I understand it any cutting of the monocoque is considered as a modification and therefore if done renders the original identity void, there are some gray areas such as sunroofs which I think they will allow as many cars in the 70's and 80's were retro fitted with them. They do let very minor mods for clearance of steering columns and such like but it is very difficult to determine how far these can be taken. As such its best to avoid any cutting to be on the safe side.
Any non structural panels outer can be cut and modified. For example front wings on a car like a MK1 escort where there is no inner wing meeting an outer to form a structural box section.
One option is to mount the radiator in the boot with the engine like a BIS, with a decent fan and an air scoop from underneath should keep cool enough. I have a Fiat 600 Abarth radiator cowling that I may fit to may car, the radiator will fit into it with the pipes running underneath.
The other thing I was thinking about was to put the radiator above the engine underneath the the engine cover (propped open Abarth style). Again it would need some ducting and some big holes in the engine cover to vent the airflow. I have seen a lot of water-cooled off roaders in the US with this kind of arrangement. A 126 might look quite funky with an Abarth style periscope (see Abarth X19 but bigger) scoop coming up from the engine cover ducting air into a radiator.
Another option is to modify the front bonnet to scoop air past a radiator and then vent it out in front of the windscreen, the problem with this is you would have to route the waterpipe through the body in some way therefore cutting the shell!
my understanding of the monoqock or however you spell the damm thing would not include the front wings or front panel it will for all legal purposes stop at front bulkhead dont have enough knowlage with computers to provide pictures or a sketch but usualy the monoqock is significantly shorter than the whole car so venting front panel should not be a problem likewise extending rear bolt on panel and rear hatch for room should be ok
I would classify the 126 front panel as part of the chassis, if its like the 500 the inner and outer front wings and welded together to form a box structure. The front panel is an integral part of this. When I spoke to ace about the holes that I had put for air flow in the front of my 500 Giannini they felt that it was a monocoque modification which is why I'm building this car with the radiator outside if the body. This is the clarification ACE have had from DVLA:
With reference to the further query, VOSA have advised that they would prefer the following statement:
What constitutes a monocoque is that of how an OEM manufacturer would view it. The chassis or `cage` assembly and all components that form it, less any cosmetic panels or infills that make no structural consideration to the monocoque or its component parts.
However, we must emphasis that this information is given for general guidance and each case will be judged on its merits.
The statement 'each case will be judged on its merits' does not help, you may consider that the front panel on a 126 is not structural, some of the inspectors within the DVLA may also, but on the day, if you get inspected and the opinion of that person is that it forms part of the structure then its BIVA or off the road... no argument... That's the problem, its too ambiguous. What is needed is definitive definitions then we would know what the limitations are and we could build accordingly. However its probably easier, cheaper and with pressure from Europe, politically more viable for them to ban all modifications.
Ideally each manufacturer should be able to tell us exactly what forms the monocoque structure for each model but are they going to go back into there history to do this? I think not! They just want to sell you a new car.
Heathens! >:(
i think the answer is in the bonnet then as i could think up ways of ducting air to a radiator as for finding a route for piping then there is already a few places to route through without cutting for starters i do not have any heating so the airvent is perfect.
