Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: smallcox on June 12, 2010, 04:53:51 PM
I find myself replacing the capacitor in the distributor often, i beleive this is due to heat from the engine/exhaust breaking it down. I know it is in parrellel with the points, so I want to move it next to the coil where it's cooler. 8)
Has anybody done this as i beleive it is fitted to the distributor for practicality reasons and should not have any bad effects in doing so.
never tried it, but you might get a bit of signal degradation if you move it too far. Would be worth seeing if you can tack it to the cowling bolts on the left side of the engine, should be nice and cool over there
I had the same capasitor/condenser on my Gamine for 5years without problem it was the original. Drve down to Garlenda no problems, had some problems with irratic running the day I was returning turned out to be valve clearences but I was told to change the Capasitor/condenser this was done and the original junked new one in place started home. Good job I was given a spare because by France I had to replace it. Found some old stock in a small village in France 2 No, both had to be replaced before I reached Britain. Had to replace again when I arrived home. Wish I had never junked the original so I have fitted 123 ignition to remove the problem. Good luck in finding a good one, they dont make them like they used to.
As long as it has a good earth....can't see what the problem would be.
I did that on a bike I had, the capacitor would die and it wouldnt rev so put it up under the tank bolted to the coil.
Cheers Guy's,
I contacted H & H ignition solutions and they said as puddlejumper the parts come from Asia and are not that great. They also said moving the condensor is a common practise to get away from major heat source and should have no major affect ,so i have now moved it next to the coil and time will see. [-/ [-/
