Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Darrell on June 03, 2010, 10:06:07 AM
Still got pre-ignition under load :(
Not as bad as before but it's still there.
Timing light says ignition is spot-on
123 website forum claims it could be carbon deposits...
Going to try changing plugs ::)
any ideas?
She's got to not be hot now as she's got the bigger sump etc etc, well, you guys know what I've had to do to it recently!
When you bought your 123 ignition did you buy the complete distributor, or just the top cap Kit ???
the only time i have had pinking on an aircolled engine is when its getting hot, did you change the sump for a deeper item and did you fit an extended pick up with it?
Pete got the cap kit and fitted it to my dizzy.
Mick got the extended pick-up for the sump.
It's weird, it pink sortof half way throttle, tap-off and it goes away, full throttle it also goes away... :-X
Hi Darrell, Did you strip out the distributor as in the instruction manual including the bob weights and springs ??? Just a thought :)
Hi Pete, yes stripped-out the weights, I was surprised at that. But then reading-on they've made the 123 'clever' with different curves for levels of engine developement which still confuses the hell out of me as what the heck is stage 1 etc etc.
Reading the 123 website, they have a forum where I noticed I'm not the only one who has this problem.
They recomend changing fuel to a higher octane to help remove any carbon deposits in the combustion chamber.
I tried Halfrauds for some new plugs last nite and to my horror they don't seem to even list the 126 any more, and do not stock plugs for it!
There was mentioned the possibility the plugs could have been damaged in my previous overheating episodes causing the pre-ignition....until I change them, I can't comment.
At this stage I dare not put the new 40/80 cam in until I can get it to run properly standard so am thinking of booking it in to dynotune for the whole treatment, rolling road etc, they should be able to tell me what the problem is. I've been putting it off because my accelorator linkage is a bit of a bodge but it works ;)
In an earlier thread you mentioned that you had 60deg advance @ around 3000rpm which would be the 28deg + the mechanical advance, It was just a thought.
If you have another standard dizzy i would swop it over, if it cures the problem it could be the 123 is faulty and take it from there ;)
Hi Pete,
yeah I was being a dim wit, it is advancing to about 28 degress max. It wouldnt run at 60.
I'll try the dizzy change, I have two spare ones, won't harm anything to get my fingers into the dizzys and check them out.
I am increasingly suspecting the 123 is at fault but need proof.
With my timing light I can only estimate the full advance and can only set it up at 10 degrees at idle.
I'm thinking some of these professional tuners will have fancy gear to prove it one way or the other.
£90 it'll cost me to run it on a rolling road but at least I'll get to find out if my mixture is right and ignition system is right.
Perhaps get some interesting facts on the hp produced before putting the cam in [-/
Hey, never been a big fan of after market electonric ingnition systems and on our cars they run close to the exhaust system but then i am just old school not even got a computer :oops:.
Does your engine start pinking from as soon as you start your journey or after say a 5 mile run?
Reading from your post on this forum have you skimmed the head to raise the CR? Pete's route is definatly worth trying changing your distributor for a standard one to see if this cures it but normally pinking is worse under load, ie full throttle the fact it does this at mid throttle and not full throttle i would suspect carb as the advance does not change on the ignition when you move the throttle from mid to full position.
Rolling road session would show faults but it is only as good as the ooperator that has knowledge of the instrumentation on these engines (carb,ignition) modern engines dont have these and tuners are losing the skills
keep us all posted, your'll get there [-/.
Changed pulg from ngk's to the Bosch W200T35 which runs 'cooler' than the original spec. W175T35...seems to be alot better.
The NGK's had little deposits on them, I wonder it that would have caused it?
If your happy with the 123 now, I seem to remember that when they used a bike carb on the 650 buggy they enlarged the main jet to 1.5mm, as Steve mentioned it could be running too lean.
Could be running a bit lean although starts without the need for the choke, a bit breathless till warm.
The carb is being replaced with a Dellorto FZD very soon (when it arrives) but right now I can run foot flat up hills with no pinking, which is great. The hill I couldnt do 30 up I can now do 40! [-/
The change for the Dellorto is because the tuner says he has jets etc for the Dellorto and wouldnt know if he can work the KeiHin from the CX500 so if he wants a Dellorto, he's getting one ;D
Before it goes to the tuner, it'll get the 40/80 cam so it'll be interesting times for me these next few weeks/months :oops:
I'm not after a seriously fast beasty but simply want a little more power if I can ;D...get me out of trouble when I need to.
I'm not using the motorway any more to take wifey to work as I feel it was putting too much stress on everything, not that I avoid motorways at all costs but just feel it's more happy at speeds of up to 50 on a regular commute. I believe I'm using less fuel too [-/
Seems these new plugs have done wonders, I'll take pics of the build-up on the old ones. It could still be running lean, but hopefully I'll know soon :oops:
Its easy enough to run a 1.5mm drill through the main jet :D I have a honda CX500 bike and using just one of the carbs is only supplying 1 cylinder 250cc [-/
The blitz tuning pages for the 126 seem to have disappeared from the web.
hi Pete, yes I see your theory however my theory was : although it is one carb per piston on the CX, it's only drawing-in fuel once in a four stroke cycle whereas our engines are drawing in twice thus it is just two sucks not one no?
It's not a big bother because the CX carb will be binned soon for the Delorto and like I say, she's running really well at the moment, can't see the need to mod the CX carb as it'll be gone soon :oops:
I have a theory of leaving well alone, as she's a daily commute. I have learnt my lesson the hard way as fiddling in the evening often leaves me wheels-less in the morning :oops:
I'll have a look on the weekend at what size jet is in there, I have a 1.5mm drill and a spare jet so will give it a go [-/ I wonder what size the jets were in the CX...
Basically, Although both pistons move up and down together its still a 4 stroke engine, only one cylinder is charged with air/fuel at a time, On the compression stroke one cylinder fires while the other cylinder is on the exhaust stroke and visor versa.
In theory by using a carb that is set up to give the correct air/fuel mixture for a cylinder capacity of 250cc means that by using the same carb on a cylinder of 325cc (650 twin) there is 75cc that is running on fresh air ;)
;) with the amount of money that has gone into my little bug recently I could do with it running on water :oops:
Another issue that has come-up with the CX carb is the lack of a return to the tank which my pressure regulator doesn't like for some reason.
It shuts the fuel flow off completely from time to time, a quick fiddle with the adjusting knob and she's off again...
Another issue to be hopefully resolved by the Dellorto [-/
WARNING >:(
The world a carb see's is so different on every single engine and on every state of tune. if your engine is pinking this sounds like pre detonation and this will destroy pistons, head and valves. back off the throttle as soon as you here it.
Ps running a carb rich rather than lean will protect the engine ;D
