Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: K666STW on May 18, 2010, 04:48:06 PM
So just been out cleaning the car and as I passed the sponge over the N/S front wheel I heard a small clunk. :o
It seems pushing and pulling at the top of the wheel shows some amount of play, It's the same on the other side but not quite as bad.
What could this be? I've check the wheel bolts are on tight but that's as far as I could go.
Kingpins and bearings would be in my list of things to check ...
Kingpins did cross my mind too. Cars been so well behaved the last 12 months aswell.
Well problem part solved. The play was in the hub so have tightened up the hub to lessen the play. Seems to have worked, but should I be worried about what cause the play? The lock nuts hadn't moved so the wear must be from inside?
