Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: TLT on May 17, 2010, 08:49:22 PM
Title: New wheels for my 91' 126 Bis...
Post by: TLT on May 17, 2010, 08:49:22 PM
Do y'all know if 5"x13 KN MINATOR (http://www.tyresave.co.uk/alloyskn.html) will fit directly on my 91' 126 bis ?!!! They're making them with the correct PCD.
Actualy, last week I was supposed to get some wheels from one chap 5.5"x13(http://www.leboncoin.fr/equipement_auto/106573220.htm?ca=12_s) & when we put them on, the front was perfect but the rear was touching the inside of the car body, we had to remove everything...
Original steel rims 4"x13" aren't available anymore and mines definitely need to be changed as they're in very bad shape...
What shoes can I put on my ride ?!!!! On top of this my budget is limited...
Thanks in advance and sorry for my english I'm a French chap
Title: Re: New wheels for my 91' 126 Bis...
Post by: Pete126 on May 17, 2010, 09:36:11 PM
Hi TLT,
Welcome to the forum :D
I Had the same problem when i fitted my TSW wheels, I used a 5mm Spacer on the rears with the correct spigot rings and that sorted the problem out [-/
Post by: TLT on May 17, 2010, 09:57:35 PM
Thanks for your reply Pete, what size are your TSW wheels ?!!! Are Spacers mandatory with 5" wheels ?!!! Where did you get your spacers & which one should I get for my 126 Bis?!! Did someone try the KN MINATORS ?!!!
Another question connected :
Would those steel rims fit directly :
2450 rim for Cinquecento 06-95 - 03-98
Taille:  4.50Bx13 pouces 145/70R13
Entraxe: 4 trous x 98 mm 155/65R13
Déport: 36.5 mm
Bore: 58 mm
Less style but cost less & safety first, I drive my kids with it !
Post by: Pete126 on May 17, 2010, 10:23:57 PM
The TSW are 5.5j wide, the 5mm spacers are available here in the U.K. at most of the car shops.
The Cinquecento sporting wheels I think fit without a spacer ??? Maybe someone can confirm that there are quite a few 126's with them fitted, If so the cinq steel wheels should fit O.K. and be Safe.
Post by: smallcox on May 18, 2010, 04:20:27 PM
hi,
You do not mention size of tyre you are fitting, i fitted 185/55/13 to 13 inch wheels on 5.5J's and only just required slight attention to the front wheel arches to clear when turning lock to lock.
Steve
Post by: TLT on May 18, 2010, 07:54:29 PM
Actualy I've got 4 brand new Uniroyal Rally tyres size 135x70x13 (original size) I intend to fit on my new wheels...
Post by: Pete126 on May 18, 2010, 08:12:49 PM
Hi Steve, the tyre size on my 126 5.5j 13" wheels are 165x55x13 which seems to be the popular size for cinq sporting alloys.
TLT, Can you borrow a spare steel wheel from the cinq to see if it fits without rubbing ???
Post by: TLT on May 18, 2010, 09:19:12 PM
Unfortunately no.
here are the cinque steel rim specifications:
4.5"x13
PCD: 4 x 98
Offset: 30...38
Centre Bore: 58.0
126 bis wheels spec are :
The series dimensions for the 126 BIS tires are: 135/70 R 13 68 S
The rims are: 4.00Bx13 H2 Steel, bolt circle 4x98, ET 31,5
Wheel bolts: 4 pieces, bolt circle 98, thread: 12x1.25, torque: 7 kpm
Does it match ?!!!
KN MINATOR on a 126 bis anyone ?!!!
Post by: Pete126 on May 18, 2010, 10:53:16 PM
The ET (German) measurement = OffSet (English) they are the same measurement, The cinq steel wheel is 1/2" wider (13mm), if you measure from the inside wheel rim to the nearest part of the wheel arch where it can touch, take away 7mm and that should give you the clearance, Seeing that there are alot of 126 with sporting wheels 5.5jx13" you should not have a problem fitting the steelies, also the tyres you have will fit better on the 4.5 rims they would be stretched on the 5.5 rims.
Post by: TLT on May 19, 2010, 08:05:09 PM
Once again thanks for your reply Pete, we're coming to the end, it is very useful and therefore I know I can go for the cinquecento steel rims if I want to coz that should do it. Budget is around 200€.
If we talk about style, I'm still interested in the KN MINATOR 5"x13" ET20. Budget is 350€
The guy at Tyresave (Duncan) is very cool and replies to lots of my questions. Here's what told me:
"135.70.13 will certainly fit correctly on 5x13" wheels,
and 5x13" wheels at ET20 will fit correctly on the front and the rear.
The important figures are 4x13" ET31.5 (for the 126bis), which means the backspace is 95.5mm.
The Minator wheels are 5x13" ET20, which means the backspace is 96mm.
So you can see the clearance to the inner wheel arches is virtually the same.
So the wheel+tyres will not rub..."
Do you agree with all this ?!!! what about my 135x70x13 tyres on 5" wheels ? Will they be OK or streched too much ?!!! What is your advise ?!! What would you do ?...
Thanks for your help y'all !
Post by: Pete126 on May 19, 2010, 09:20:58 PM
Sounds good to me  :P If the experts say yes [-/
Post by: TLT on May 19, 2010, 09:38:51 PM
Who's the expert ?!!! I didn't catch your last post sorry....
Would you go for the KN minator ?!! 135x70x13 on 5" wheels OK ?!!!
Post by: Pete126 on May 19, 2010, 10:04:12 PM
Sorry, if the expert at tyresave (Duncan) says you can fit your new 135 tyres then that should be O.K. Just check the price they quoted includes shipping them over to France.
Post by: TLT on May 19, 2010, 10:34:31 PM
Ok, I'll let y'all know what I did & will send pics with the result.
Post by: Worm on May 29, 2010, 03:00:06 PM
Hi TLT
I am also in ther process of sourcing alloys for my 1983 126, i have been talking to Ducan at tyresave also. He recommended that 155.65.13 on the Minator 5"x13 would be the recommened size tyre. I think that the rims will protrude or at best be flush with the tyre if you fit 135.70.13 tyres. As the rim width is 5" (127mm) but the wheel width is nearer to 6" (152mm) therefore if you fit the 135.70.13 tyre 152-135=17mm divide by 2 = 8.5mm each side of rim, so allowing for a little extra on the tyre side wall form may not be the best size tyre to fit though, if you dont want to kerb the alloys.
Post by: Worm on May 29, 2010, 03:07:50 PM
PS
i also concluded with Ducan that the ET20 offset with the 5"x13 Minator due to my original steel wheel having an offset of around ET30 will actually have the same inner distance to the suspension stut all bar 4mm closer, and that with the 155.65.13 tyres the wheel and tyre will protrude the extra 1" from the arches.
My original steels are 12" though so i guess with the later bis they made them with 13" steels like you have.
A question for all those out there with 5 or 5.5" alloys, do they protrude your arches enough to affect by the MOT are there arch kits out there for the 126 to rectify this if need be??
Post by: Dom on May 30, 2010, 11:00:54 AM
As an alternative tyre size/choice, you could go with 145 60 R13s. I have Michelin Compact tyres of this size fitted tp the Cromodora 5j 13 rims on the front and 155 65 13s on the rears. I initially bought a set of 4 of the Pirelli 155 65s, but they rubbed a hell of a lot on the front so i had to go for something creating a smaller rolling diameter. I wouldn't want to go any narrower than the 145s as they are almost stretched as they are giving a very low profile.
Post by: Worm on May 30, 2010, 04:06:11 PM
Thanks for your reply. I think the 145s will be a little narrow to give my rims protection if i scrap a curb, i am thinkinng of 165 all round as i have 30-35 clearance to strut on front and 20-25mm clearance to underbody work/suspension on rears which having the 165 will offer more rim protection and hopefully not handle badly due to the extra width ::) The rolling radius will be near enough the same as the original wheels so hitting the arches vertically or turning hopefully wont be a problem ;)
Post by: Worm on June 01, 2010, 03:53:33 PM
hi,
Steve
After a bit of research i have concluded i could actually (if budget permits :o) get 5.5x15" Minator alloys with 175.40.15 tyres as the rolling radius will be the same and having 15" rather than 13" should bling the look a bit more. The strut cleanances look ok to.
Steve what sort of distance do your 185's offer the rim for protection is it about 10mm or more? Also what did you need to actually do to your arches to make lock to lock not rub, was it a whisker off the arch or grinder time ;D ;D?
Post by: gsxr126 on June 02, 2010, 03:58:02 AM
Hi Worm,
Be careful with fifteens as they can be deceiving. I have 15x7 wheels on my project car with 195/45/15 Continentals. They fit on the hub and studs perfectly, and they dont foul on the shocks. The problem is however that i cant (or rather couldnt) turn the front wheels more than 1 inch as they foul on the front and rear of the wheels arches. I have cut heaps out of the front guards to get the lock to lock clearance right but you dont want to be doing that to a standardish car. 195s on a seven inch rim would be close to a 175 on a 5.5 inch rim in rolling diameter so i'm guessing the rolling diameter would be similar to mine. Have a look at my "hunt for wheels over" thread on here and you'll see what i mean.
If you can confirm that you get the same diameter as the thirteens i would go for it, but make sure its the same ( i will be very surprised if it is)
Dan
Post by: Worm on June 02, 2010, 05:15:36 PM
Blown that idea out the water as they dont make 175.40.15. Any wider and the rolling radius is all messed up and probably have to knock arches about too. Back to 13"
Post by: gsxr126 on June 02, 2010, 09:42:40 PM
Thought so, from memory the smallest profile 15 tyre is a 45 series
Post by: TLT on June 28, 2010, 09:57:33 PM
My wheels are currenlty on the way... Actually I've already got 4 brand new 135x70x13 tyres & Duncan told me it would fit the wheels so I intend to try them on & I won't have to change the wheels for the MOT as well... Thanks I just hope it will be fine ... Do you mean it's risky to fit'em on ?!!!
Post by: Worm on June 29, 2010, 03:03:38 PM
Have to wait and see what they look like, they may end up being flush at best with the rims as the rims are 5" = 127mm plus about 10mm each side = 147mm. Depends how wide the actual 135 tyre is, may give you a few more mm's of rim protection. From discussions with Ducan i would have gone up to 155's as a minimum.
If you dont go near Kerbs it wont be an issue anyway.
Hope they look great. Post up a pic when fitted
Post by: TLT on July 20, 2010, 09:28:43 PM
Hello y'all !
Just to let y'all know I received dem wheels & they fit perfectly & straight on, I'd recommend dem to everyone who'd like to replace the original steel wheels. It looks good too & you can fit on the original tyre size in case you want the car to be ready for the MOT.
Thanks again for your help on this !
TT
Post by: Worm on July 20, 2010, 09:54:38 PM
Hello y'all !
TT
Excellent news, they look great ;)
