Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Darrell on May 05, 2010, 09:10:57 PM
Grumpyness here....my oil light comes-on at idle :(
Plan is to check it with a gauge and if it is oil pressure it might be bearings :(
Could just be a poorly pressure swith too .
I hope it is..hasnt stopped but hasnt broken down yet :oops:
We used to have a lot of problems in the early days with the plugs in the crankshaft moving and allowing the oil to escape there. It still gives you some oil pressure with revs but causes the light to come on at idle. The other one I have seen is the air intake hose fallen off not allowing the engine to get cooler air but sucking hot air from around the motor.
thats a very good point.. does it only do it once the engine warms up? it could be overheating.. a hot engine will cause your problem.
The problem I feel was the engine overheated, this caused the rear main bearing to pinch on the crank which resulted in a piece about an inch long being ripped out of the rear main bearing on the inner(crankcase) side.
This simply allowed oil to pass directly into the sump.
The oil light did go out when reved.
I'm the sort that wouldn't let it lie so carried-on till I had disassembled enough to find the problem.
The overheating I feel, I may be wrong, was because the 123 ignition was over-advancing. At idle it was firing on 1o degrees advanced but then what it did when it advaced I have no idea.
I've decided to keep the 123 as a back-up in the boot till I can figure out what is going-on with it. I'm back on points with no overheating problems at all.
The tell-tale was pre-ignition when it overheated.
