Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Adamamon on April 18, 2010, 06:58:15 PM
Title: Little indicator issue
Post by: Adamamon on April 18, 2010, 06:58:15 PM
Hmm,  my indicators are being odd.
At this second in time none of them work. But earlier they did work fine, the only issue was that with the lights on, the back left break light flashed instead of the yellow indicator light.
I looked inside and saw some weird circuit idea of a light wiring but that turned out to be normal for the Bis and I realised its actually very simple but I'm sure that's not the problem. Just a wire somewhere but any advice?
cheers
Add
Title: Re: Little indicator issue
Post by: Amateb8 on April 18, 2010, 07:34:56 PM
Blown fuse?
Post by: Adamamon on April 18, 2010, 10:51:23 PM
Good answer! Now where do I find said fuse and what do i replace with?
As in what fuse. lol
Post by: goombas on April 19, 2010, 06:58:41 AM
in 126 always the stronger you havei :P
Post by: michaelodonnell500 on April 19, 2010, 08:59:54 AM
It sounds like a bad earth.
Run a cable (jump lead will do) from the earth connector on the light to the engine earth strap, or any part of th engine block as long as its clean.
This should confirm that you earth wire is not working correctly.
Post by: goombas on April 20, 2010, 06:52:37 AM
i thoght so to but it was a fuse he says
