Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: ciccio on March 27, 2010, 02:41:49 PM
Title: Engine Problem
Post by: ciccio on March 27, 2010, 02:41:49 PM
Hi Guys,
Can anyone shed any light with the following problems?
I purchased a 652cc engine(recon) and have done approx 600 miles since fitting it.
It has a larger capacity(deeper) Abarth sump but it came with a standard dipstick,so the dipstick reading isn't true.
However have filled sump until it shows on the lower mark on the dipstick so in my opinion isn't over full.
What i have noticed is that the bottom of the  air filter housing has a small amount of engine oil in it.
Is this beacause there's too much in the sump? or does my engine have other problems.
I may drain and refill with accurately measured amount and keep an eye on it.
Also have fitted 123 ignition and starts and drives(pulls) very well,however it spits and pops back on the over run.Any ideas guys?
Thanks guys
Ciccio
Title: Re: Engine Problem
Post by: Rusty's Uncle on March 27, 2010, 03:15:33 PM
I was under the impression that the higher volume sumps achieved the extra capacity by going wider rather than deeper. A standard sump has an effective internal depth of about 10.5cms. Any other mods on the engine as you have a number of settings on that ignition  ???
Post by: thepuddlejumper on March 27, 2010, 05:53:43 PM
Ihave an abarth sump fitted to my gamine, I fill up to the fill mark on the dipstick.  The additional volume of oil is said to help with cooling.  In any case the oil level should not change.  Iwoulg go by the dipstick level.  The deeper sumps should be spacer cast in to the sump base to support the oil pump intake, well thats what I have been told.
Post by: ciccio on March 27, 2010, 07:35:54 PM
Hi and thanks for your prompt replies.
I recall when fitting the Abarth sump that it had a baffle/spacer built into it.
I will fill to the mark and keep an eye on it.
With regard to the ignition its currently set on 0.Its not running any mods and is a stock 650 lump.
It seems a little better since i changed the exhaust from the sport one to a stock one.
Post by: Pete126 on March 28, 2010, 11:11:30 AM
They all tend to pull up a drop of oil into the air filter but usually its nothing to worry about, check that the oil filler cap has the disc at the bottom of the spring, A few owners on the forum have fitted an oil catch tank.
Post by: Alfons1972 on March 28, 2010, 11:58:54 AM
the type of oil sump does not lead to a chance of oil level. The dipstick reading is correct.
If your oil sump is the shown one, what is important is, that you mount the "no shaking" element https://webshop.fiat500126.com/index.php/katalog/artikelinfo/1971-1-no-shaking_element_for_4_liter_aluminum_oil-pan.html
and the oil pump inlet extension https://webshop.fiat500126.com/index.php/katalog/artikelinfo/1970-1-oil_pump_inlet_extension_for_aluminum_oil_pan.html
to avoid your enginge sucking air in fastly driven curves
(http://img7.myimg.de/16082009112657e49_thumb.jpg) (http://www.myimg.de/?img=16082009112657e49.jpg)
Post by: Rusty's Uncle on March 28, 2010, 02:03:13 PM
Re the 123 ignition , I thought that the 0 position was for setting up the timing before you switch to the right curve for your car  [-/
Post by: Darrell on March 28, 2010, 05:54:52 PM
0 is also the standard setting for the 500/and standard 650 engine.
1 is the same with idle control. according to the book of words from what I remember.
I'll try find it and scan it for the website, for future reference :)
I'm running mine on 1 :)
Post by: ciccio on March 28, 2010, 08:48:18 PM
Hi Guys,
An update soo far.............
I have today noticed that with the car idling and the oil filler cap off it seems to be breating a lot more than it should.This  may be the issue for oil being present in the air filter housing.looking at the abarth cap it hasn't got a relief spring as  per the original set up and assume oil is being forced back up through the breather pipe into the air filter housing.
The heavy breathing would lead me to think excessive crankcase pressure but will speak to the guys that supplied the engine to see if they can provide a reasonable explanaton.
Problems apart it pulls like a train and sounds fantastic.,Have tweeked mixture slightly and will  flick the 123 setting to  1 over the next couple of days to see if this sorts the popping etc.
Any advice will be sincerely appreciated.
Post by: Pete126 on March 28, 2010, 10:11:43 PM
Aaaar you did'nt mention the abarth rocker cover ;D in that case you just need to fit an oil catch tank and block the hole where it connects to the air filter.
[Click Here] (http://club126uk.co.uk/smf/index.php?topic=2599.msg28862#msg28862)
Post by: bis13 on March 29, 2010, 08:41:58 AM
with regards to the abarth rocker cover make sure the inner part does not come loose there is a anti splash lip inside and this can come loose it will sound like a bag of spanners if it does, also make sure the rocker shaft/tappets are not fouling on the cover as i found that they are not the best made bit of kit and can be a little tight the reduced size bore on the breather will make it seem to be pushing out more air make sure you keep the anti flash back gizmo in the breather pipe and run directly into a small catch tank. the poppping you describe is probably the excess fuel thats not been burnt igniting when you lift off and it enters the exhaust and causes it to combust do you run an electric fuel pump?
Post by: Alfons1972 on March 29, 2010, 08:01:08 PM
can't it be possible that the piston rings are leaking?
Because in this case there will be a too big pressure in the crankcase and therefore there will a leak of oil to the air filter?
just try the following: please check the pressure of compaction on cold engine. And then check the same after putting some oil into the cylinders. If the pressure is afterwards higher then it seems that the piston rings are out of order...  :o
Post by: ciccio on March 29, 2010, 08:50:38 PM
Hi Guys and thankyou all very much for the replies so far,
Am not running with an electric fuel pump,just the original type.
I did play around with the mixture yesterday and it has improved slightly hoever it does still occasionally pop and spit back.
I changed the rocker cover back to a standard one and there was still in my opinion an excessive amount of pressure which would lead me to think rings etc.
The guy that supplied the motor told me to to re-torque the head and re-set the tappets and this will reduce it breathing so much,but am not totally convinced as its only done 600km since being fitted.(tappets were set just before i fitted it)
I will try and find the gauze thingy that was in the original breather pipe and see if i can slide it in.
Any advice guys will be sincerely appreciated.
Ciccio
Post by: Pete126 on March 30, 2010, 07:39:04 PM
The easiest way to find out if the the piston rings/valve guides are shot is to get someone to follow you and get them to observe the exhaust pipe when you accelerate/de-accelerate if there is a problem with the engine it will blow blue smoke out of the exhaust, if its clean then its O.K. The backfire can only be due to either the ignition timing, Has it been timed up with a strobe light on the setup position, or incorrect inlet/exhaust tappet settings,
Post by: Rusty's Uncle on March 30, 2010, 08:52:31 PM
Going back to the start of your thread , you said it was a recon engine . Now bearing in mind that going back almost as long as we have had the internal combustion engine there have been guys whose idea of a recon engine is a degrease & paint job , then flog it & hope it lasts for the 3 or 6 month warranty then you might like to get a compression test done. I think that there may be a few suspect suppliers trying to cash in. I spoke to a long time 500 / 126 specialist a week or so back who confirmed that it is a growing problem  :oops:
Post by: Rusty's Uncle on April 05, 2010, 05:53:58 PM
Seems that it ain't just engines that may well be dodgey in the refurbishment department but it seems that you have to beware of so called refurbished stub axles from some suppliers. This is not a new thing as I have seen a number of reports before of recon units that fail the MOT. If you have a problem with king pins you can source a new rebuild kit under £20 & if you have a traditional motor engineer on your patch then you can get a proper job done.
