Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Rusty's Uncle on March 16, 2010, 01:32:43 PM
OK if I am going to be able to refit a Weber 30 DIC carb to the 795ccs Alquati engine then I need to get some special nut/studs made. I have a guy who can do the machining but I need a small piece of hexagon bar , preferably slightly larger than 13mms A/F but no bigger than 16mms A/F . Also prefer High Tensile if poss .
Also not sure if some sort of bakelite or similar insulator would be advised between the manifold base and the cylinder head ? Any ideas ???
not sure what length you are after? perhaps an old allen key would do the job?
:D Chris that is an inspired idea & I love that thinking outside the box [-/
I will follow that up as it would probably have enough material. The only problem there may be with that machinability of the material which might be a problem with a high grade hardened item but a lower grade tool steel allen key could do the trick ;D
try heating the allen key up to red hot+ leave to cool slowly..should soften it up a bit [-/
Nipped out to my garage and found my largest allen key , a very rusty 5/8" (about 14mms) which may do the trick :D. Also now found some bar stock on eBay. I was hoping not to go down the heat treatment road as do not have the proper equipment now . Annealing is no problem but getting the right temper on a complex shape could be a bit tricky . A nice bit of medium to high carbon steel or an alloy steel would be nice [-/
Took a new hacksaw blade to the allen key today and it made a small cut so will now see if my mate can machine it. Next problem is that I am wondering If I should have some sort of insulator, like on the standard engines , between the manifold base and the cylinder head. Most of these things seem to be bakelite but it would appear that bakelite sheet does not exist. I reckon that I would need something about 6 to 8mms thick. Any ideas on this one ???
perhaps you could use a product called tufnol it's a machinable type plastic, not sure what grade is the best for your application?
http://www.directplasticsonline.co.uk/TufnolSheet/
i got quite a few old big allen keys . if you have no joy let me know
Chris you are on fire this week with those ideas & links [-/
I had thought about Tufnol as I remembered it from my apprentice days but had not researched it. I looked at that link and they do a sample service for £2.50 so I will ring their tech guys next week to ask about the best grade :D
You could also try a phenolic spacer off a go cart engine. I've used these for mounting injector stacks on my V8.
