Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: DavieH on November 25, 2005, 11:45:11 AM
Title: My BIS has cruise control!!
Post by: DavieH on November 25, 2005, 11:45:11 AM
I've discovered a new feature on my BIS....cruise control!! All I need to do is take my foot off the accelerator and it maintains its speed...brilliant! Well, almost...unfortunately, I cant turn it off when I want to.
Anyone ever had a problem with their throttle pedals sticking? I've pulled the carpets back and it possibly seems to be something with the pedal linkage. I've given it a jet of WD40 but it could be in the cable. Unfortunately its cold and dark when I finish work making it a bit tricky to work on at the moment. Are there any particular weakpoints in the linkage / cable routing that could be the cause before I go diving into the problem? Are there exposed areas of the routing underneath the car that could have frozen up or any bends in the routing that are tight by design?
Any ideas would be appreciated
Dave
Title: yes spray it
Post by: richard on November 25, 2005, 12:54:44 PM
try and spray where the throttle cable reaches the carb
hope this helps a little
i had a citroen ax 1.4i which did the same thing
i used to spray pedal frequently, inside the car, and it sorted itself
i am sure yours will too
Post by: Chris Lakin on November 25, 2005, 01:40:42 PM
is wd 40 what should be put on? not some sort of grease? of the sticking bit? try to find out where its sticking, i think Richard is right, i think its the throttle spring try putting some grease on that too.
Post by: DavieH on November 29, 2005, 10:59:25 AM
Problem solved!
I got the spanners out last Friday. On closer inspection, it appears that the problem was due to mud and dirt coming off my shoe over time, falling down around the base of the accelerator and getting drawn into the transfer tube that runs from the base of the pedal across the driver's footwell and into the central console. This had caused the linkage to stick over time. I suppose this is an inherent problem possibility with a floor-mounted pedal.
So I disconnected the throttle cable at the engine - the spring there is in good condition so nothing to worry about there.
Pulled back the carpet/mat in the driver's footwell and undid the two bolts securing the transfer tube to the floor.
Removed the pastic trim in the central console as far as the gear lever and pulled back the carpeting.Watch out for the little washers...easily lost if you dont have a good magnet or quick fingers.
Disconnected the throttle cable from the end of the lever. I then cleaned the pedal and tube assembley and applied grease to both ends. This allowed the linkage to rotate really easily within the tube with very little resistance. I then refitted the pedal, reconnected the cable at the throttle and took the opportunity to readjust the tightening on the accelerator cable as it had developed a little bit of slack over time beforehand (beware! if you do this on a freezing cold day, take into account that the cable may stretch a small bit in the heat...probably only a tiny bit though).
Back in with all the carpets, trim and mats and I fired her up...no automatic cruise control any more and definitely more responsive (which isnt a surprise to me now that the throttle closes when you take your foot off the accelerator for a change)
Overall time to fix - about 45mins from start to finish with freezing cold hands on the driveway
Thanks for the advice![/img]
Title: Re: My BIS has cruise control!!
Post by: Kent126 on November 20, 2010, 07:11:54 PM
Great advice here, havinf the same problem myself on my aircooled. Intend to look into it this week, when I get some spare time. Will print this off! :-)
TOm
Post by: bis13 on November 21, 2010, 10:04:25 AM
be carefull as its possible that the cable is about to give up i had this on my bis and even after clearing away the crud and greasing the pedal up it broke. fortunately it happened in a bis and i rigged up a hand throttle using the choke cable. if this happens on the aircooled version it can be done to get you home but you must find a point to get the cable through the rear firewall a tip is always have some good strong nylon cord and a good length of stainless/steel wire just iin case of emergencies.
Post by: Kent126 on November 21, 2010, 08:58:47 PM
Nooooooooo!!!!!!! Don't say that! Not more new parts! lol.   :P
Ok, thanks for the advice. I will strip it right down and have a good look, and order a new cable if required. I can't complain, the car has been off the road for 12 years or so, and things will have seized, or will need replacing. Most of the parts are still original as far as I can see. Im sure once all of the niggles have been ironed out he will be a great little runner. He is running 10 times better already  [-/
Got a day off on Thursday so will get well stuck into the car!
Tom
Post by: prezes on November 22, 2010, 01:28:14 AM
Common problem with it.
The spring on the end of accelerator cable is to weak when pedal has no clarification .
I placed additional bigger spring attached between carburettor lever and the body.
Now accelerator pedal works harder but I like it under my big boots in winter. [-/
Post by: Darrell on November 22, 2010, 10:03:21 AM
I prefer a bigger spring on the pedal rather than the carb side as a bigger spring on the carb side adds load to the cable.
Obviously with an increased load it's wear will be higher.
