Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: dougie_b on March 06, 2010, 07:40:07 PM
Hiya everyone, I'm new to the 126 scene but have agreed to help my brother try and remove an engine and gearbox from a 126 bis tomorrow as his gearbox is knackered and we've found a suitable one for spares but will have to remove the engine and gearbox as it's being sold to us as a unit.
I'm just looking for some hints/tips for removing if possible? Is it a tricky job? I've never worked on a 126 before and we have no haynes manual so will be a case of learning as we go.
If anyones online between now and then and has hints/tips please explain what we will need to do? I have a selection of tools and engine crane etc as have replaced engines in other cars but never a 126 yet... :)
Doug
Having the manual would be a big help, but I'll give you an overview. I have only ever dealt with aircooled units so I probably wont caver everything you need.
remove carb/choke linkeage, fuel line dizzy leads, starter power cable (and secondary) clutch cable and you've got most of the fiddly items sorted.
clutch cable securing bolt is very awkward, if you have a 13mm ratchet spanner it will help alot
with the car on the ground access the 4 drive shaft hub bolts for each wheel located at the end of each drive shaft. you can only see 2 at a time, so being able to roll the car back/forward allows you to reach them all pretty quickly.
at the very front of the gearbox disconnect the gear linkage (10mm & 13mm spanner) also unscrew the speedo cable.
Jack up and support the engine and box a jack under each is best if you can.
Undo the gearbox mounts
undo the rear panel
lower the jacks and roll the car forward (this is usually when you realise you haven't disconnected everything!
With a bit of practise it can be done in about 30 mins
Hope this helps
Michael
Hi Dougie, Michael has just about covered the removal, don't forget to disconnect the top and bottom radiator hoses the heater hoses next to the carb, disconnect the three vacuum hoses on the carb and the vacuum advance on the distributor.
When you disconnect the drive shafts be aware that there is an anti rattle spring in the ends, these have a habit of going ping.. usually down a grate or into the neighbours garden.
Here's a picture of the rear panel that shows the location of the 4 bolts that hold it on to the chassis. Don't forget the top row of 10mm bolts on the top edge of the panel and the main bolt that holds the engine mounting.
(http://i103.photobucket.com/albums/m152/pedro126/P1010311.jpg)
How to remove? Call Lad :) :) :) :)
