Fiat 126 Chat => Fiat 126 Chat => Topic started by: Little Enzo on November 21, 2005, 12:56:28 PM
to the right of the choke - what does it do?
It's a starter motor operating lever!
The bowden cable attached to it pulls the manual type solenoid on the starter motor which then makes it operate.
Enzo, you have an FSM right? In that case its the heater lever, pull it up and warm air will gush forth into the cabin, thats the theory!
thanks, thatll help for the winter.
also is there any harm in driving with the choke 1/2 up, as enzo dies if i drift and the chokes down.
thats not really good, I would guess your fuel mixture is on the weak side if you have to have the choke up, or your carb is worn? check it out as running with choke on isnt good! the mixture screw is prone to adjusting itself as the little O ring on it can wear out, I got a new ring for 20p off a carb specialist.
thanks mate, enzo is fine now chokewise he must have just needed a good drive (500miles) 1 stop, no problems seemed to do the job, the heat is nice from the starter and choke is working perfectly now.
absolutely mint operating order and he still looks like a gem. fantastic.
