Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: slash72 on February 16, 2010, 02:56:06 PM
Title: engine swap
Post by: slash72 on February 16, 2010, 02:56:06 PM
Hi !
i wanted to ask you some things about the 126bis
I am planing to put a motorcycle engine in the BIs but the question is will it fit in the original engine compartment, because i want to make it road legal, and if ill have to modifiy the top of the engine compartment(the boots floor) it will be noticable and i will fail the mot in my country...
and could you provide me the dimensions of the engine?
Title: Re: engine swap
Post by: dajwid on February 16, 2010, 03:26:02 PM
Car will need lots of modifications, what gear box and transmission are you planning on using?
Don't listen to the 'a bike engine just drops in stories' it's a lot of fabrication and head scratching I'm afraid.
Post by: slash72 on February 16, 2010, 06:40:38 PM
i know that its going to take a lot of work, and i have it all covered allready in my head , but the problem is if the motorcycle engine(i.e. honda cbr 600) will fit in the engine compartment or will i have to modify it
the gearbox is going to be the same
Post by: dajwid on February 16, 2010, 07:32:02 PM
Simples, measure one. People have stuck V6 engines in, Flat fours, Allsorts, there is certainly space for a Fireblade engine  as its only the size of PC  :D, but you will still need to fabricate mountings and work out how to make it actually drive the wheels, are you planning on chain drive?
Post by: gsxr126 on February 17, 2010, 12:54:29 AM
I dont think you can run a chain drive if you mount a bike engine in the engine compartment. The engine needs to be mounted with the drive side facing forward so it can be connected to the drive system. I have a mid mounted 1300cc suzuki engine in my fiat, but i'm also in the planning stages of dropping a 1000cc gsxr engine in the back of one of my nikis as i would like a standard looking vehicle from the outside.
This is how i plan to do this mod: Parts being used - 1000cc GSXR Suzuki Engine, R200 Nissan S15 Silvia IRS Diff & driveshafts, Nissan S15 tailshaft, about 5mts chrome moly tube.
What i think i'm going to do: To mate engine and diff together i plan to use the tailshaft from the nissan, shorten it to the required length, and modify it to accept the splined shaft that the drive cog bolts to. The end that bolts to the diff will be a standard bolt on. Once that's done I'll dummy mount the whole assembly to see how it sits, fit the driveshafts to see how long they need to be & get them machined to fit the original splines on the fiat. Then its a matter of fabricating mounts for engine and diff.
What comes next - gearchange, clutch & accelerator mechanisms. Gearchange will be up/down shortshift style and I utlised the original shifter and shifter position on my mid engined car and it works very well. I still havent figured out how i will convert the backwards/forwards motion of the gearstick to an up/down movement as the engine is mounted sideways (some sort of rocker system i'm thinking). Clutch is hydraulic and i will simply get a longer hydraulic line fabricated and mated to my clutch pedal with the original clutch lever mechanism from the bike (have this setup in my other car and it works really, really well). Accelerator is cable and just needs an extension from engine to pedal.
Then there's other things like a reverse gear etc....
As for fit, I'm sure you shouldnt have any issues with a 600cc engine as an R1 yamaha engine fits in sideways, with just the bootlid opened a tad. I plan to cut my bootlid and fit the wind catcher scoops you can get for these if i have clearance issues.
You shouldn't need to cut anything out in the engine compartment, the gearchange mechanism may need some mods to the body though.
Hope that helps
Dan.
Post by: 1973/126 on March 18, 2010, 09:28:21 AM
 I was thinking the other day if anyone tried a Mini engine in the 126? Do you guys think this would be possible? It is compact with the gearbox sitting under the engine. Loads of people use them in the Blitz buggies which also use 126 engines and mechanics. Not sure if there is enough space thought in the back of the 126 without any major mods ???
Post by: gsxr126 on April 22, 2010, 07:15:18 AM
Would definately be possible. The issue with the mini setup is that you need to have the whole assembly forward of the back wheels, which means a back seat engine bay.
Excellent as a racer (mid mounted), but try explaining that to a copper when he sees you driving on the street.
Post by: RSPSTEVE on April 22, 2010, 07:18:14 AM
I drove a smart car the other day , engine is a 600 cc turbo and tiny also sits in the back , any thoughts ?
Steve
Post by: Rusty's Uncle on April 22, 2010, 02:09:42 PM
Just went to see a neighbour who runs a specialist brake business , I have ordered some brake discs that I am hoping will suit the 12" wheel brake conversion after they have been machined. He said that he had kept something for me and gave me a copy of "PRACTICAL PERFORMANCE CAR" , February 2010 issue. Has an article about a bike conversion on a Barchetta bodied over a purpose built space frame. Triumph Daytona 995ccs triple engine , 148 bhp , revs to 10,800 & 148 bhp etc, etc  :oops:
Post by: gsxr126 on April 23, 2010, 05:11:38 AM
Steve
Hey Steve, Do you know who the drive system worked??
Post by: RSPSTEVE on April 23, 2010, 07:57:09 AM
I dont to be honest but it looked like it what go in , the engine is tiny .
Post by: thepuddlejumper on April 23, 2010, 04:45:42 PM
Smart engines without gearbox and drives are expensive approx £800 from ebay.  Could be an expensive mod.
Post by: RSPSTEVE on April 24, 2010, 07:46:30 AM
there was a right off on ebay a while ago for 600 complete car but front end foooked.
Steve
