Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Rusty's Uncle on February 13, 2010, 05:15:27 PM
Title: Dodgy Running / Misfire
Post by: Rusty's Uncle on February 13, 2010, 05:15:27 PM
The last proper run out I had in my little motor was on Boxing Day , partly because of the weather and also the engine was running strange & I did not fancy freezing my cashews off as I wait for breakdown recovery. I can only describe it as a misfire but quite strange. When warmed up the engine ran a bit like one of those stationary engines at a Steam rally , spitting & coughing now and again on tickover , power a bit down & also missing at higher revs & speed. I checked & reset a few things but it was a puzzle. Started up today and went round the block a couple of times & problem still there but then I looked at the online fuel filter  :oops:
Small trace of rusty water in the lower corner  >:( So I guess that at £1.12.9 per litre it is worth BP , Shell & Texaco sneaking in a little H2O which probably does not show on a modern motor but does on a little 2 cylinder job.
OK , conspiracy theory but I have definately picked up some dodgey petrol  >:(
Title: Re: Dodgy Running / Misfire
Post by: Darrell on February 13, 2010, 09:54:38 PM
At these new fuel prices we might need to do some work on running 126's on home-brew!  :oops:
Post by: Rusty's Uncle on February 20, 2010, 02:30:31 PM
 :D The engine is definately starting to run a bit better now , still some signs of the H2O misfire but went out for a "foot to the floor" 20 mile run which has blown through the traces of water in the filter but I am going to run the car till it runs out of petrol , carrying a full can , then fill up with fresh  [-/
Post by: Amateb8 on February 20, 2010, 03:32:59 PM
Was it a year or two ago, Tesco or another supermarket chain was wrapped for selling dodgy fuel. Motorists that have sustained engine damage made a claim on Tesco.
Post by: bis13 on February 20, 2010, 03:53:16 PM
are you sure you havent topped it up with your soda concoction?
