Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: richk on February 11, 2010, 04:41:39 PM
Hi guys.
My reverse gear has been getting harder and harder to select lately. Now it's almost impossible. It feels like its gone in but it's in 4th. It will go in but it takes about ten attempts.
When I'm driving in top the gearlever's all over the place, so I'm hoping it's a worn linkage somewhere, although the forward gears selects are great.
Any pointers before I go and freeze my bits off in the cold? :cry:
try changing the gearbox oil, i changed mine pretty soon after acquiring the car as had similar issues (not particularly suprising as was laid up in a shed from 1979 - 2009!). i find the linkage / gear selection is pretty slack anyways, certainly compared to a lot of other older cars.
I had the similar problem with our 73. It wasn`t selecting gears at all when we bought it. There are two gear linkage bushes inside the tunnel. One right at the back and one in the front. My were non existing, I guess due to the age of the car they just fell to bits. Try to have a look if you got them in place and do some adjustment on the gear linkage rod.
After I did this my gear change is perfect.
>:( I just spent 30 mins typing an in depth reply on this & it disapeared into the ether when I pressed post so b*****ks. but it will be those bushes. I have some bits here if you need them quick as I was just about to overhaul a spare gear lever assembly [-/
Here is a pic. Ricambio do them for £7.50, or take Rusty`s offer.
Cheers guys, will get on to it.
??? I have seen those items in the Ricambio eBay shop and they confuse meas I do not recognise them or how they mount in the housing.
Just taken more pics , one of a gear lever / linkage that needs repairing. You can see the press in bush has broken and fallen out of the back of the housing also the anti-vibration spring has fallen off. The second pic shows all the parts you might need for a complete overhaul [-/
Have a look at the linkage on the end of the gearbox first. There is a rubber goodie inbetween the box and the shaft that goes to the stick, it could be knackered or simply loose.
Somehow I doubt those bushes would make it that bad.
I found my gearbox mountings had moved which caused the whole engine/gearbox to rock over one way. This made 3rd a nightmare to find. It's better now but when I can be assured I wont get frostbite when I step outside I'll have another look.
From my experience the bushes make the stick rattle when they are worn, but a pig of a job as the while tunnel has to come out.
Maybe I think it's a pig because I'm too big for working inside the car :P
You 126 guys have got it easy as you can remove the carpet section over the tunnel to do the work. On a 500 you have to remove the seats so you can remove the one piece carpet before you can tackle the job. The rubber goodie you mention is the bit shown at the top of the picture. Although I have seen a couple where oil has started to attack the rubber I have never known one to fail completely. Plus I have never had to replace the bush at the rear end of the link rod as if the gearbox is mounted correctly then I think it takes far less stress. [-/
The one at the back of the tunnel is in never land, never seen it never want to :oops:
Thanks for your help guys. Decided to bite the bullet and have a go, that's the beauty of self employment!
Right, how hard can it be- a couple of bushes?
No access under the car so, 3 seats out, centre console out, seat belts out, carpet out, rear tunnel cover out, front tunnel cover out.
Jack car up, undo rear rod/flexi union bolt (10mm where you can see it, 13mm where you can't- live & learn!)
Undo gear stick bolts on the tunnel, withdraw gear rod. Job done! No bushes to be found where they should be, they're all broken up!
New bushes for me then! Could someone tell me where the springs go that come with the repair kit?
I didn't find any! Do you have some spare bushes Dave! Otherwise it's Ricambio, expensive I know but local to me.
R.
I think I remember the one with the hooked-ends holds the stick against the stop to stop you putting it in reverse by mistake and the other holds the stick up so one has to push down to get reverse.
Ricambio should have bushes, and they are rubber with a brass insert, they fit around the shaft into the hole.
hope that helps :oops: not the best at explaining stuff :oops:
Thanks Dar, I think I get the drift. I see the big one that you push down against, but there's no small one. I would assume it fits sideways somehow and keeps the stick to the left when in neutral.
Ricamb do the bushes but I hate being tucked up! £15 for two :o
126fan: £3 ish for two. No contest- I'll pay the postage and wait!
Yeah the little one is tricky, it goes into little holes from the right side of the mechanism to the stick part of the mechanism.
I guess £15 is alot but then I guess if you needed it urgently they'd be there to supply it.
9/10 times with me i need it quickly as I made the foolish decision to sell all other vehicles and the 126 is my only wheels, much to my wife and family's disgust :oops:
Rusty those early 126`s have got a one piece carpet so the same stuff as the 500.
Those bushes are a right ..... of a job. I think you`ll have to take the front bit to bits too(the selector rod), as you can`t put the bush in there otherwise.
The ones from Ricambio are expensive, but I guess they would last longer and would make the rod easier to slide as they got those copper inserts.
Good luck.
The car looks good too. It`s nice to pull the carpet out sometimes :oops:
Oh I did not know that about the early 126s so that is another feature that is the same as the 500. So just checked out the early Haynes manual and the front anti-vibration springwas not fitted. If you look at the pic I posted there is an extension at the front end of the link rod and a little lug on the mount side of the housing where the spring goes so it must have been an update in the design. Were the other bits OK & if you need them quick I have them here [-/
Thanks, I will have a pair of bushes to keep me going. PM me with a price and I'll sort it out.
Cheers, Rich K.
Hi Rich , I sent a message to the hotmail address shown in your profile not sure if you saw it [-/
Reverse gear is back - and super slick! **-
Thanks Dave for the bushes and everyone else for your help.
:) No problemo & good news indeed [-/
I drove a 126 for some time with no reverse gear . Went down a narrow street one day and a huge lorry came the other way . "You will have to back up" the driver shouted >:(
"Sorry mate , reverse gear is busted , you will have to push me" :D
He backed up :D
David 1 - Goliath 0
Ha Ha!
