Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: ciaoflyer on February 05, 2010, 10:53:52 AM
Hi
The towbar I bought has been fitted for a while now and all seems to be ok apart from one thing. When it was first fitted the engine rocked around so much that it hit the towbar and made a god awful noise. This was due to worn out gear box mounts and engine mount, so replaced these and all is fine. However, when the rear end hits a bump in the road or I go too fast over a speed hump there is a loud bang from the rear. The tow bar is bolted to the suspension pivot bolt and the noise seems to be coming from that area! Do you think that I may need new shocks and spings?
Hi Ciao,
I recently replaced my RHS control arm and found that the were two 'shims/spacers/washers' on each side of the arm where it bolts into the chassis. Have a look at that area as not including these shims would cause that kind of noise.
Thanks I shall check it out. Just has a thought maybe I am missing a bump stop on the suspension!
Turned out to be the engine mount. Bought a new one but only aircooled ones are made, the Bis one raises the engine by another 10mm. All was not lost though I used the old Bis bushes but used the new spring from the aircooled mount as it is the same. No knocking at all now! Very happy! :D
