Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Chris Lakin on January 30, 2010, 09:03:52 PM
Title: Sandblasting
Post by: Chris Lakin on January 30, 2010, 09:03:52 PM
http://www.machinemart.co.uk/shop/product/details/clarke-cpsb100pressurised-sandblaster
I am considering getting the above pressurised sand blaster, would anybody recommend this? as apposed to getting a decent compressor i.e. 3hp and then just getting a feed / siphon adapter
Also what grit grade would be best?
Any advice would be appreciated.
Regards
Title: Re: Sandblasting
Post by: thepuddlejumper on January 30, 2010, 09:19:31 PM
Not used this type used the syphon type worked OK but what a lot of mess.  If you intend to grit blast a car or large panels you will need somewhere to do it.  I grit blasted the underside of my 500 and was cleaning the garage up for months after.  I thought I had containment sealed with polythene sheets.
Post by: Chris Lakin on January 30, 2010, 09:35:11 PM
Thanks for that Ralp,
didnt think of that aspect of it, so thanks for bringing it to my attention! Dont think my mum would be too happy, might try doing it outside.
May go down compressor route as will need to respray eventually anyway. Good compressors arnt cheap though!
Regards
Post by: bardy on January 30, 2010, 10:06:38 PM
well we built our own sand blasting box out of wood and then used 2 litre coke bottles to cover the light up so it dunt get damaged and then put  sealent round edges so it wouldnt cum out and a hole for the hover thats as old as my dad and shot blasted all my brake parts, my suspention parts and evan my fuel tank ( had big holes in it) and loads of  other things but we didnt do any body panels and the we unscrewd the box and it packs away nicely and youd not no it was there, we used sumthin from m dads work ant a clue where it was from tho
Post by: landyman on January 31, 2010, 07:05:23 PM
3hp comp will strugle to give you a genuine 10-11cfm so won't run that blast pot 19cfm required is probably the minimum asked of compressor give me a ring for advice. hopefully restarting my workshop in next couple of weeks, just to give you an idea my comp supplies 300 cfm and only just keeps up with demand from my blast pot and breathing system it is very messy, grit gets everywhere and is a pig of a job.if you want to buy spray equipment get in touch for sizes of comp/guns. good luck andy.
Post by: michaelodonnell500 on January 31, 2010, 08:44:13 PM
Hi Chris,
I've got one of those syphon sandblasters, not had a proper chance to use it yet as I left the grit out in the damp and its not had a proper chance to dry out. I got a bag of recycled glass grit from Ebay 25kg for £10 + £10 postage, no idea where to buy it around here though, but I haven't tried too hard though!
Get a second hand compressor from Ebay, then you can get a half descent brand. When you're finished and looking to sell it, you should get back what you paid for it.
Post by: Chris Lakin on January 31, 2010, 08:52:01 PM
Thanks guys, for all your advice, again exactly what i was looking for, i have no knowledge of sandblasting. I just want to make sure my pennies go on buying the right equiptment.
was going to go for one of these compressors with the presurrised blaster. 3hp and  14cfm air displacement.
http://www.machinemart.co.uk/shop/product/details/airmaster-tiger-14-60-air-compressor/path/airmaster-2
those glass beads off ebay sounds cheap, alu oxide is £40 a tin!
Regards
Post by: bobblehead on February 09, 2010, 06:30:12 PM
use kiln dried sand ... works a treat, although get a inline filter to take the moisture out the line so it doesnt clog your gun .
youll need a wacker of a compressor to sand or media blast ...
ibe tried it with serveral compressors, works well for few seconds, then compressor kicks in trying to fill back up ..
im prob totally wrong but it happened to me ..
Post by: hudsonhenry on February 09, 2010, 07:02:59 PM
You gotta be very careful with sand or glass grit, I would not use them without an air fed mask. You only have one set of lungs and silicosis is not a good way to go!!! You even have to be very careful sweeping up as the sand breaks up on impact to tiny particles and can get thrown up in the air very easily. Your best bet would be chilled iron or alu oxcide.
I have been thinking about soda blasting but did some research. It appears one of its advantages is also a disadvantage. When you soda blast the soda leaves a residue on the metal that stops it from flash rusting for weeks (good) but the residue needs to be washed off thoroughly with water (which a flash rust inhibitor can be added). There is talk on some of the custom forums in the US of primers not sticking to the surface properly even when they have apparently been washed down properly (BAD). Some of the paint manufactures now state that there paints are not to be used on cars that have been soda blast.
Could be internet scare-moungering but would you take the chance on a £2000.00 paint job?
Nigel
Post by: Jan-in-UK on February 14, 2010, 09:05:40 PM
Does anybody know any good sandblasting place? I have two sets of wheels, maybe even three + some small parts 2 or 3. I am not going to do it by myself as I can't so would prefere to give it out to get it done. I am in Slugh but more/less local would be good. London??
If you know where they can do it good and cheap please advice. Thanks.
Post by: michaelodonnell500 on February 14, 2010, 09:17:32 PM
me
Post by: Jan-in-UK on February 14, 2010, 09:32:45 PM
PM'ed  - :)
Post by: richk on February 17, 2010, 11:59:03 AM
I cleenz macheenz are in south London. They know all in the ins and outs of blasting - and their work is superb.
They do have a web site but don't know it. Try google.
Post by: Rusty's Uncle on February 17, 2010, 12:24:31 PM
 :D Hi Jan , sorry to hear about your "Small Parts"  </8
Now I see that you live in Slugh you need to let me know your address so I can send you the pin badge that you won in the Haiti Earthquake auction.
That was a great donation & it is plain to me that what you lack in the parts department , you more than make up with your generosity  </4 </4 </4
