Fiat 126 Chat => Tuning & Customising 126 Models => Topic started by: gsxr126 on January 22, 2010, 05:22:47 AM
Title: Can you flip the front leaf spring around to lower the front end???
Post by: gsxr126 on January 22, 2010, 05:22:47 AM
Hi all,
Just saw a 1960 500 fully customised. The bloke that owns it said he just flipped the front leaf spring over to lower it. It was TF low for my liking, but just wondering if anyone on this forum has tried this on a 126.
Thanks in advance
Dan.
Title: Re: Can you flip the front leaf spring around to lower the front end???
Post by: Jan-in-UK on January 22, 2010, 02:01:58 PM
Many times I have been told people just do that to 126's in Poland. But I never get round to check if it is really possible. But I think it should be. Now when you reminded me about this I am tempted to try.
Post by: stuey on January 22, 2010, 04:10:02 PM
surely the bottom leaf pushes against the ones above which is what give the spring its tension, by flipping it you are just allowing it to spring on the "then" bottom leaf which has been moved to the top (effectivly removing all other leaves from the equation)
methinks it will handle like a sack of dung and be way too soft- get a reverse eye spring and it its not low enough cut down the alloy blocks (up to 11mm can be removed safely) or remove 1 leaf from the spring (this is what I did and it was plenty low enough and handles like its on rails...)  ;D
Post by: gsxr126 on January 22, 2010, 07:26:55 PM
Thanks,
I will try flipping it first to confirm Stuey's thoughts, then if you're right Stuey, the sack of dung will sit in the hood to improve the handling, I mean, I'll get a reverse eye spring etc....
Post by: Jan-in-UK on January 22, 2010, 08:07:57 PM
I will test it as well. Just in case - where can I buy reverse one and how much will I have to take out of my pocket?
Post by: Pete126 on January 22, 2010, 08:21:48 PM
You can't just flip the spring [-/  Because the spring effect is at the eye ends of the spring unlike the leaf spring on back axles on some motors where the spring effect is in the centre (hope that makes sense)
(http://i103.photobucket.com/albums/m152/pedro126/Untitled1_edited-1.jpg)
If you look at the diagram I think Stuey removed No12 ??? but I would suggest you place it under the main leaf No15 as if you remove it all together  the leaf will not sit in the flexible mounting bracket No3.
For safety I would recommend a reverse eye spring :D
http://www.500mania.it/ns/index.php/store_gbr/leaf-spring-1.html
Post by: michaelodonnell500 on January 22, 2010, 11:39:59 PM
I agree with Pete, the construction of the spring prevents it from working upside down. try it if you wish, but its several hours spent underneath a car for no effect!!
From what I can see, removing no. 12 and placing it under 15 would lower the suspension, but would also soften it. I would suggest splicing 2 springs. Move the eyelet leaf (no.15)  closer to the top, but add a leaf giving 6 leaves which would stiffen the front suspension rather than soften it.
Other than this you have the option of paying someone to reverse the eyelet of no.15, removing the plastic liners, sitting the spring on the floor, with a mate standing on top and heating it wiath a set of burning gear until the arc of the spring softens. lower suspension, but not stiffenend.
Post by: bis13 on January 24, 2010, 11:37:00 AM
500 mania in italy sell the best priced reverse eye leaf springs around 70 odd euros and have a choice of 5 and six leaf springs.
Post by: gsxr126 on January 27, 2010, 01:52:33 AM
Spoke to Mr custom 500 again and he said he had to flip leaf nos 10 & 12 to do this mod. 10 to fit the spring cups and 12 to stiffen it up. It apparently does the job very well.
I will try this as i need to replace my entire front suspension anyway.
Post by: fly on January 30, 2010, 09:25:06 PM
I just had mine relaxed by a nice man down the road, took it apart, put the locating top leaf (10) on the bottom or vice versa, bolted it all back up and voilà, one slammed 126.  It sits right on the bottom of the shocks and po-go's along though so suspension and any kinda handling are things of the past.
Post by: bis13 on January 31, 2010, 03:48:26 PM
so in other words it didnt work as the car does not handle properly now . if you buy a reverse eye spring it makes the car handle better and at the same time reduces the ride height, couple this with either uprated and shorter shocks or the rear a/c shocks upfront it will also make things better.
Post by: gsxr126 on February 01, 2010, 02:48:27 AM
Hey Mick,
What do you recommend, 5 or 6 leaves. Will be looking at 500 mania soon. For 70 pounds its a bargain, I had a quote for modifying my spring and came in at $425 AU. Hate these overpriced assuie suppliers.
Post by: thepuddlejumper on February 01, 2010, 01:25:02 PM
126FAN have a reverse eye spring at £60 I think
Post by: Dom on February 02, 2010, 03:35:18 PM
Hey Mick,
Go for 5. The 6 leaves are meant for a (Giardiniera 500 Estate) and only have 6 leaves to compensate for the extra weight of the fully laden estate. 5 Leaves on the reverse eye are more than stiff enough, in fact too stiff for many as a lot of the 'older' guys on the 500 club have actually reverted back to the original leaf spring as they found the reverse eye ride too stiff. I like it, except when driving over the increasing amount of pothole and crap roads, where it feels like the car is going to rattle to pieces!
Post by: fly on February 03, 2010, 09:16:48 AM
Not exactly, it depends on what you are trying to achieve; I dont think the reverse eye springs lower the car enough so for my purposes the flip has heeded the desired result.  Next job is to change the shocks as you say, budget allowing I plan to invest in a set of adjustable coilovers from Blitz, that should then allow me to remove a few of the leafs. Its all about experimentation and trying different things until you get to where you want to be - for me the cars almost as low as I want it, next is to sort out the handling.
Post by: bis13 on February 03, 2010, 10:35:34 AM
maybe so but "your needs" equate to making the car dangerous for the sack of image? dont get me wrong as i agree with what you are trying to do however the lowering and control of the car should go hand in hand and one not compromised for the other. surely if you are trying to get so low you must have issues with the bodywork by now unless you are running cycle tyres?
like i said before the reverse eye will drop instantly 30 to 40 mm , shave the spring supports and thats another 10 to 12 mm and this is to have no adverse effects on the handling it only improves it. whereas if you wish to go lower then you need to start looking at relacing the leaf spring with a wishbone unit and chucking on some coilovers .
if you keep a flimsy leaf spring and chuck coilovers on then that will not stop the flex caused at the point where the spring is connected with the knuckles and all in all just look gucci with no real effect other than on your pocket.
hope you get to zero mm clearance as i think its well trick i get this stance by letting the local scum come round and steal my wheels.  [-/
Post by: stuey on February 03, 2010, 11:09:31 AM
you need to change the shocks if they are bottoming out- I used air cooled rear shocks on the front of mine...it will problee then sit low enough for you, Id still go the reverse eye route to be fair if just gives you a good head start on getting it in the weeds without adversly affecting the handing as it doesnt upset the suspension geometry so much.
Post by: fly on February 03, 2010, 12:47:34 PM
Was trying to upload a photo of my new rims...but was getting onto...until ive saved enough pocket money I was planning on swapping the the shocks around as I run bigger tyres up back and dont mind the jacked up back end stance (135/70's & 135/80's at the mo but havent decided on tyre choice for the newbies as yet).
Sorry, drifted off topic there, in summary from me, yes you can flip the front spring but at the sacrifice of many other desirable attributes.
