Fiat 126 Chat => Fiat 126 Mechanical Problem Solving => Topic started by: Korius on January 19, 2010, 08:01:34 PM
Title: Problems with starter
Post by: Korius on January 19, 2010, 08:01:34 PM
Hello. I am new in this forum. I am from Lithuania and i have an aircooled 126, 97'.
I am having a problem with the engine start. Then i turn the ignition on and turning the key the starter makes some cranky noise and engine rotating very slowly and wont starting. I think there is a problem with starter, becouse when  I am pulling or pushing the car, activating 2nd gear and releasing the clutch the engine starts and works normal as it needs to work.
Where the problem can be?
P.S. sorry for bad english language. :)
Title: Re: Problems with starter
Post by: fightingtorque on January 19, 2010, 09:56:09 PM
battery, starter or the cables are at fault.  try using the battery from someone elses' car.  if the battery is just flat but not faulty, you should be able to jump start it with jumper cables, it should then recharge whilst running, unless there is a problem with the charging (alternator/dynamo).
if the battery is faulty, then it might not even start with jumper cables unless you disconnect your battery, and also it will not charge properly.  the cold weather affects the batteries, makes one that is in marginal condition normally become unusable once the temperature gets down around freezing.
Post by: Korius on January 20, 2010, 04:27:30 PM
I have tried to connect to other battery with jumping cables. There was the same noise and nothing special. I am also tried to fully recharge the battery at home. Nothing happened. I think that my battery is faulty and i need to buy new one. :)  First I'll try with other battery and if it works it would be this problem.
P.S. Now my fiat is in car service, For a body repair. So i can't check with other battery right now. Thank you for your help. Then i get my car, I'll check and write here what's the problem was.
Post by: prezes on January 28, 2010, 11:05:17 PM
Starter problems? :oops:
1. When you turning ignition key...:
- and the dashboard red lights are going dark one of your +(plus) cables is broken
(for example solenoid starter switch +) and is touching the body frame.
-  is  the red lights are on and nothing happen (you can not hear click from the starter)
 solenoid starter switch has copper blade black from the carbon on places where is in contact with
 power (it has to connect + (plus from the ignition) with the starter.
....(you will need to use soldering gun and get black PVC plastics cup open ad clean copper plate)
- if you heard click and starter is not moving crank it may be main +(plus) cable broken between battery and starter  engine
  ..(simply you can check if there is + on the bolt near the starter) if the power is there starter is burn-out.
2.If you managed to run the starter and in stead 3 time /second crank is running like 1 time per second making mad noise (sometimes red lights on dashboard are going darker) it means that starter motor is weak or often it has exercise play on copper bearings.
 (usually is going worst when is colder in the morning and engine oil is much heavier)
.. you can do the test remove both spark plugs and spark-plug cables  (flying petrol may cath the fire from any spark) and try if the same starter is runing faster on cold engine. To check bearings you have to :
A. Disconnect red (+ plus) cable from battery
B. Disconnect wires from starter
c. Take 13mm spanner and remove starter
... on the table catch starter motor axle and try to shake it ... if you fell any playing the bearing have to be changed (0.5mm luz and you may not turn the crank). You may need to order a pair of copper bearings . they looks like small copper pipes but this is not the same material than plumbers used. The old unit have to be removed with hammer and new placed gently in. Best starters has 0.0xmm play and they starts engine on one crank move.
Good Luck  ;D
Tom
